Hello All
What alternatives is there instead of anti-freeze to run in a Model A to stop corrosion? |
Water pump lube & anti rust from auto store.
Can you provide me with the names of the products please. A person told me they run a cap fill of drill cutting compound, any one tried this ?
I do the same as Glen in post # 2 .
Neats-foot oil?
Charlie Stephens |
I get mine at both Auto Zone and Advance Auto Parts . Several companies offer this product . Gunk is the first brand that comes to mind . The counter people are usually helpful . I ask for water pump lubricant . The kind that I use comes in small bottles for five or six dollars per bottle . It also does a good job of stopping sound of a a squeaky water pump seal .
If desiring to use distilled water - NAPA MAC's 1300
https://www.napaonline.com/en/p/MCC1300 Has been frequently mentioned previously on the Barn, additionally I add a bottle of Red Line Water Wetter. Usually flush/backflush yearly. As needed white vinegar or thermocure flush//backflush. Winter storage drain water and fill with antifreeze, in spring drain antifreeze and save it for winter-reuse. |
I have been told by more than one person who all should know that cutting oil will turn to jelly in the cooling system so I don't use it. I use an american product which gives great lubrication, rust resistance and is compatible with all antifreeze additives, not that I use any of those.
It's sold here branded as "Cyclo" Anti Rust & water pump lube and is made by Cyclo Industries LLC in Florida. Unlike most other soluble oils, it does not attack the hoses either. If I rub my fingers together after dipping one intot he coolant, I can feel the oiliness. You might gather that I recommend this stuff. Has anybody else used it?
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say. I sometimes wonder what happened to the people who asked me for directions. If I am not in trouble, I've done something wrong. |
I have never heard of Cyclo products (before now). They have many different products lubrication and corrosion. Here is a link to what (i think) Synchro is referring to. http://cyclo.com/cyclo_product/anti-...p-lubricant-2/ I have no idea where to buy it. Everywhere I looked online it is Out of stock.
The Master Cylinder Enjoying life at the beach in SoCal... Last edited by The Master Cylinder; 02-26-2019 at 04:52 PM. |
For years I've used distilled water and Water Wetter from Autozone. This winter we had a new NAPA store open in town and I went in to see what they had. They didn't carry Water Wetter, but their product is called NAPA Kool. It comes in a 16 oz. bottle and the number is 4056. It's a little more expensive but I'll give it a try this summer.
Marty |
#12 | |
Maybe it's easier to buy them here than in the country where they are made! Maybe an oportunity here for some enterprising barner?At the bottom of the link posted by The Master Cylinder,there is a "Contact Us" for them.
#13 |
Thank you all for the replies. My thinking for the alternatives for Anti Freeze was to see if they don't cause the same gasket leakage issues as anti freeze. The Cyclo product is available in New Zealand, so I am keen to try.
#14 |
I use a water soluble cutting oil, it Improves Wetting, Cleaning & Lubricating During Metal Cutting & Grinding; Prevents Rust & Corrosion.
https://www.napaonline.com/en/p/SLRSL2512
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
#15 |
I have used antifreeze for the last 40 years--- what gasket leakage??
#16 |
I have used "water pump lube/anti rust" for years. For the last 10 - 12 years been using Sta -Lube brand Soluble Oil ( CRC No. SL2512) with good results. Says right on the label "For automotive and industrial cooling systems as a rust preventative". No jelling or hose problems to be seen. It is a soluble metal working oil, as far as I can tell it is the same stuff as the water pump lube/ anti rust except in much concentrated form. I believe that I purchased it at a NAPA store, came in a 1 quart jug.
Joe B PS, just saw "160B's" post ...yep' that's the stuff! |
#17 |
I use Water-less Coolant in my pressurized system.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go?
#18 | |
When something works, and works so great, I never understood the need to search for an alternative. Love my 50% antifreeze in all my vehicles. Old antifreeze and drain oil make great mouse killers in the 5 gallon bucket mouse traps. |
#19 |
I don't understand the fuss about using something other than antifreeze. I've used mostly Preston antifreeze for 57 years and never had one problem. I knew a man that heard that kerosene was a good alternative to antifreeze for short term use being it would swell the hoses after sometime. He was losing water from somewhere and didn't want to keep adding antifreeze so he was using kerosene. this was in an old 35 ford log truck and he blew a head gasket and totally burned the truck with a load of stave bolts to the ground. I think antifreeze is still the best.
#20 |
50% antifreeze for me no problem with gaskets for the last 5 yrs since engine rebuilt,(15000 miles. )
