Old 05-28-2010, 07:55 AM   #7
Bill Steiner
Default Re: 1930 Steering column support change
I shimed it with two washers so it would not touch the old upper clamp. I put a rubber piece in the old top part just for looks. you can see it in the picture. I used two bolts that where under the dash rail. I did not Drill under the dash rail for the third bolt. I don't see where it was needed. Bill
Bill Steiner is offline   Reply With Quote
