Old 08-23-2018, 09:52 PM   #1
duke36
Default SW sedan crossmember hole cover
Some posts questioned the rear cross member hole cover. Attached is a photo of what appears to be an after market metal cover. The holes are also in the pan for the fabric cover straps.
Old 08-24-2018, 05:28 AM   #2
Ed Saniewski
Ed Saniewski's Avatar
Default Re: SW sedan crossmember hole cover
That takes a few pressings to make. Fords way was much cheaper using left over upholstery material.
Model A Ford Club of New Jersey
http://www.mafcnj.org
Model A Pick Up Owners and Enthusiasts
http://www.fordbarn.com/forum/group.php?groupid=5
Ed Saniewski is offline   Reply With Quote
Old 08-24-2018, 07:47 AM   #3
Scott NY
Scott NY's Avatar
My original s/w has a fabric cover. Hopefully the picture is attached
Scott NY is offline   Reply With Quote
Old 08-24-2018, 08:27 AM   #4
Dave in MN
Dave in MN's Avatar
Somewhat off topic but...
I recently removed the fabric crossmember cover on a '31 Slant Windshield to replace a rear spring u-bolt because of a stripped thread.
It would have been ugly if it had a riveted cover!
Good Day!
Dave in MN is offline   Reply With Quote
Old 08-24-2018, 09:00 PM   #5
jw hash
jw hash's Avatar
duke if you install a metal cover over the hole, your seat spring bottom will be ridding right on it. installing a fabric one is easy.
jw hash is offline   Reply With Quote
Old 08-25-2018, 08:03 PM   #6
duke36
Car came with cover, no issues with seat bottom. Have insulation on top of pan.
