Old 06-08-2018, 11:50 AM   #1
Dave O
Dave O's Avatar
Default Starter Issue
On several occasions my starter has kept turning after the engine starts and bendix releases. What could be causing this? I'm still on the original 6 volt system.
Dave O is offline   Reply With Quote
Old 06-08-2018, 03:46 PM   #2
Dave O
Dave O's Avatar
Default Re: Starter Issue
Anybody ever have this problem where the starter motor keeps running after the engine starts?
Old 06-08-2018, 04:29 PM   #3
Big hammer
Starter switch is sticking, remove and clean the contacts!
get a bigger hammer tap done
Old 06-08-2018, 04:47 PM   #4
Dave O
Dave O's Avatar
Sounds right. I'll check it out. Thanks!
Old 06-08-2018, 06:34 PM   #5
jax55
jax55's Avatar
Check the battery as well. A weak battery can cause sticking contacts as well.
jax55 is offline   Reply With Quote
Old 06-08-2018, 07:19 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
Also check alignment of the push rod, as some of the repro switches don't exactly line up, and the rod will bind.
Old 06-08-2018, 09:02 PM   #7
Dave O
Dave O's Avatar
Thanks for all the input!
Old 06-09-2018, 07:45 AM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
ALWAYS push the starter FIRM & HARD, to lessen the chance of ARCING & "welding" the contacts together. ADD this to your FULL Sheet list of "HOW TO START YOUR DAMNED MODEL A"----"Maybe" thet's why CROOKS didn't use Model As????
Bill Stomper
"THE ASSISTANT GURU OF STUFF"
Old 06-09-2018, 08:00 AM   #9
Ray in La Mesa
Once you have the starter switch off, check to see if the bronze contact strip is not catching on the cardboard insulation on the sides.
Ray in La Mesa is offline   Reply With Quote
