Old 02-16-2018, 06:55 PM   #21
CarlG
CarlG's Avatar
Default Re: mini-starter
Originally Posted by abbie View Post
Thank you for replying. Where did you obtain the switch you use with the mini-starter??
I lost the information on that, but if you would check with the guys in the Ft Worth "Cowtown A's" he is a member there.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-16-2018, 07:12 PM   #22
Keith True
Keith True's Avatar
Lee,I've never heard of a solenoid exploding.How did that happen?i've seen a lot of them go bad,but never actually open up.
Old 02-17-2018, 12:15 AM   #23
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by lee in bend View Post
I had 3 "modern" solenoids explode on my starter that was converted to 12V.
Hmmmm, Very interesting...
Old 02-17-2018, 12:24 AM   #24
Y-Blockhead
Originally Posted by BILL WILLIAMSON View Post
Some need to PRACTICE reading & comprehending the initial posters' QUESTIONS---
Haha, Now that there is a good one coming from one that rarely gives a straight answer... Keep them coming Bill. You're cracking' me up!!
Old 02-17-2018, 03:21 AM   #25
johnbuckley
johnbuckley's Avatar
I have converted my A to 12 volts. I am planning to install one of the light weight mini starters that requires a solenoid to be added. If anyone has installed one, I would appreciate describing where you put the solenoid and the starter switch, and what type switch you recommend.
thank you in advance
Ok Abbie, I'll answer your question.. I put the solenoid on the firewall near the starter, I put a quality push button switch in the dash rail to the left of the steering wheel. I would use a quality push switch capable of handling not less than 10 A momentarily.
Old 02-17-2018, 03:35 PM   #26
CarlG
CarlG's Avatar
The lightweight mini starter that I have (came from Snyder's) has the solenoid built in.
Alaskan A's
Old 02-17-2018, 03:47 PM   #27
Bob C
After rereading his post I think he may be talking about the modern
type starter drive.
Bob
Old 02-17-2018, 05:43 PM   #28
denis4x4
denis4x4's Avatar
Went to Snyder’s website and read the info on the starter. After reading the posts, still unclear if there is a 12v solenoid built in. Looking at the wiring diagram, it appears that there is. Need to know.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 02-17-2018, 08:29 PM   #29
CarlG
CarlG's Avatar
The instructions that came with mine said you could use the internal solenoid or bypass it and use an external one. I already had an external one, so I didn't use the internal one.
Alaskan A's
