Old 12-14-2017, 09:42 PM   #1
abbie
Default mini-starter
I have converted my A to 12 volts. I am planning to install one of the light weight mini starters that requires a solenoid to be added. If anyone has installed one, I would appreciate describing where you put the solenoid and the starter switch, and what type switch you recommend.
thank you in advance
abbie is offline   Reply With Quote
