Do you folks use a stand to rebuild your transmission? If so I would request you post a picture and a comment or two. I am thinking of building one and would like to see the "state of the art". Thanks in advance to everyone willing to share.
You don't want to over think this, in the day a kitchen table will do.
I have used a wide 5 wheel to nestle the trans in, on top of the bench.
Mart. |
Here's the style I manufacture and use. They will fit all Ford 3spd trans cases from '32 to '48..................top shift, side shift, and V8 60.
Paul J. |
Pipethread in the bottomplug of the case then either in your benchwise or make a floormount.
Super Moderator
Here is the pipe with a plywood floor mount. Pipe screws into the bottom drain.
Ed |
#8 | |
I've also fabbed up cradles out of the bed frame angle iron. Works great. |
Here's one I saw somewhere and copied the pictures to my files for future reference. It may be Vern Tadell's idea/design, can't remember. I've also made some legs using 3/4" angle iron that bolted to the holes in the front bell and kept the case sitting open end up on my work bench. That worked well, but no pictures available, just have to use your imagination
The last time I did one was on the floor of the barn.
Did one what??
#13 |
Naw, that was in the hay loft a sleep over that night. Thanks for the reminder tho!!!
#14 |
Here's what I use.
#15 |
Yes, I know a little overkill!
It's about the creation ...... can not help it. Jorgen |
#16 |
Rivets...have to love it !
#17 |
Just a simple box section frame to stop it rolling around, can be clamped in vice too.
#18 |
Mine bears a remarkable resemblance to the floor (with some added padding). When they're done I put them on a small padded moving dolly from Harbor Freight.
#19 |
I use a steel pipe plug ( drain plug size )with a chuck of 5/16 flat stock welded to the square. The plug goes in the bottom of the case and the flat stock goes in my vise.
Charlie ny |
#20 | |
