Old 12-16-2017, 08:43 PM   #1
Davew
Davew's Avatar
Default Ethanol Defense
Anybody use this stuff. Always try to use non ethanol but not always possible.
Davew is offline   Reply With Quote
Old 12-16-2017, 08:53 PM   #2
eagle
eagle's Avatar
Default Re: Ethanol Defense
Ethanol will work fine in an A but don't let it set for very long.
Old 12-16-2017, 09:22 PM   #3
denis4x4
denis4x4's Avatar
I have ethanol free gas delivered to the house. Makes a lot of difference on small engines and outboards. Certainly can tell the difference with much better mileage on the daily drivers and the A’s.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 12-16-2017, 10:21 PM   #4
Davew
Davew's Avatar
Ethanol Defense is an additive to counter the effects of using having to use ethanol fuel. I had never heard of it before.
Old 12-16-2017, 10:26 PM   #5
denis4x4
denis4x4's Avatar
Sometimes I’m a slow learner...I thought davew was defending the use of ethanol
Old 12-16-2017, 11:20 PM   #6
Davew
Davew's Avatar
Sorry, didn't explain it very well
Old 12-16-2017, 11:56 PM   #7
burner31
burner31's Avatar
Oklahoma is still a free State.
So I choose you use pure gas only.
File Type: jpg hey-hillar-supporters-november-2016-is-winterize-your-gas-dal-6876226.jpg (16.7 KB, 74 views)
File Type: jpg Gasohol-definition-and-illustration.jpg (79.4 KB, 55 views)
Keith
Shawnee OK
'31 SW 160-B
Old 12-17-2017, 12:47 AM   #8
Synchro909
Synchro909's Avatar
Several years ago over here, the Government allowed the addition of up to 10% ethanol in fuel. Most don't use it and straight petrol is readily available everywhere. E10 was sold at 4c a litre less than pure petrol. This discount has been eroded and now stands at about 2c. I did the calculations at 4c cheaper and on an energy for your dollar basis, it still didn't add up. Fuel is much dearer now so the difference is even more detrimental to value.The lower energy content warranted a larger discount than that. The lower energy content reveals itself in more litres per 100 km.
It would be easy for a government to increase the cost of motoring by mandating E10 and not making a large enough allowance for the lower energy content. They're sneaky like that!
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 12-17-2017, 12:54 AM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
I never heard of Ethanol Defense, and wonder what it is, or what's in it?
Old 12-17-2017, 05:14 AM   #10
Mike V. Florida
Mike V. Florida's Avatar
Every day for years.
Old 12-17-2017, 06:02 AM   #11
Bruce of MN
Bruce of MN's Avatar
https://www.bellperformance.com/fuel...thanol-defense
I searched for an MSDS, but couldn't find one.
Old 12-17-2017, 06:30 AM   #12
4port
4port's Avatar
MSDS for Ethanol Defense
Magnesium Sulfonates 55-80%.
No.2 Fuel Oil 20-45%.
Magnesium Sulfonates are used as detergent and rust inhibitor additives in motor oil. Both Calcium Sulfonates and or Magnesium Sulfonates are presently used in detergent motor oils.
4port is offline   Reply With Quote
Old 12-17-2017, 08:50 AM   #13
Ted Duke
The irony of this alcohol in the gas problem (IMHO major concession to corn growers and VERY bad for the environment in many ways) is that the standard treatment for cure if you get water in you gas you use DryGas, which is alcohol.
It combines with the water and burns off. But, you wouldn't put DryGas in your tank and let it sit, would you? Of course not.
Ted Duke is offline   Reply With Quote
Old 12-17-2017, 10:07 AM   #14
burner31
burner31's Avatar
If you Honor pleases...
Keith
Shawnee OK
'31 SW 160-B
Old 12-17-2017, 10:28 AM   #15
captndan
captndan's Avatar
I ain’t no chemist but sounds like 30% off road diesel in the gas would do the same.
captndan is offline   Reply With Quote
Old 12-17-2017, 10:35 AM   #16
40 Deluxe
I'm quite sure that off road Diesel is the same as Diesel for hiway use. I believe that ultra low sulpher fuel is the only type allowed to be refined.
Old 12-17-2017, 10:50 AM   #17
Keith True
Keith True's Avatar
Off road diesel is the same.It is just dyed to let you know the road tax has not been paid on it.I don't think I would want to be putting 3 gallons of diesel and 7 gallons of gas,(30%), in an A.It will run,but you won't like it.
Old 12-17-2017, 11:08 AM   #18
wrndln
I don't think the Ethanol Defense post directly above, means about 30% diesel in a tank of ethanol gas. If you look at the bottle of Ethanol Defense, it appears to be about 16 to 32 ounces of which is 20% to 45% is diesel per a post above, which is a very small percentage of diesel when added to a gas tank.
Rusty Nelson
Old 12-17-2017, 11:11 AM   #19
Crankster
Crankster's Avatar
Interesting to me how many additives contain petroleum distillates that we can buy for a fraction of the cost of "special" miracles in a can. A small amount of diesel added to gasoline seems to inhibit vapor lock as well, and is said to provide some defense against exhaust valve recession. Gasoline containing ethanol runs on the lean side, it runs "OK", the real problem though is it does not store well, and also tends to dissolve accumulated sludge and sediment, is hard on conventional rubber components and aluminum castings.
Crankster is offline   Reply With Quote
Old 12-17-2017, 11:48 AM   #20
Davew
Davew's Avatar
At their web site they compare it to sta-bil, sea foam and others. No mention of Marvil oil. At 1 oz. per 10 gallons it should be ok to try shouldn't it?
