Old 10-18-2017, 02:26 PM   #1
mll1446
Default 1947 ford brake question
looking for size of copper washer that goes on brake line?. Does anyone know size of these washers? or part number for auto part store for an equivalent washer? thanks for help in a pinch.
mll1446 is offline   Reply With Quote
Old 10-18-2017, 02:39 PM   #2
Charlie Stephens
Default Re: 1947 ford brake question
I can't help with the details but I bet this guy would have them in stock, Dennis Cling at clingsaftermarket.com, (480) 777-1202
Charlie Stephens
Old 10-18-2017, 04:20 PM   #3
rg130
rg130's Avatar
Give Richard Lacy of the Early Ford Garage he is an expert on brakes. He has a website, located in West Covina, CA. Ph# 626-338-2282.
rg130 is offline   Reply With Quote
Old 10-18-2017, 04:54 PM   #4
JSeery
JSeery's Avatar
The Green Book list them (at least some of them), the ones for the back of the master cylinder are 2151 (.61 ID/.81 OD) & 2152 (.51 ID/.81 OD) for example.
Old 10-19-2017, 01:12 PM   #5
hook00pad
The fitting is called a banjo fitting. I bought an assortment pack of copper washers at OReilley's Auto Pts.a few weeks ago.
Hook
hook00pad is offline   Reply With Quote
Old 10-19-2017, 03:39 PM   #6
Tony, NY
I know Harbor Freight has a kit of copper washers that would probably have the size. https://www.harborfreight.com/80-pie...ent-67526.html
Tony, NY is offline   Reply With Quote
Old 10-19-2017, 03:57 PM   #7
Paul Bennett
I've bought banjo washers at NAPA. Only use them once and like other gaskets,they squeeze flat removing their utility.
Paul Bennett is offline   Reply With Quote
Old 10-19-2017, 10:05 PM   #8
fordor41
fordor41's Avatar
washers at autozone and advance auto
fordor41 is offline   Reply With Quote
