Old 10-10-2017, 04:25 PM   #1
newshirt
newshirt's Avatar
Default U-joint Play
There is about 1/8 inch play in the four shaft ends of my U-joint. And, the shafts are no longer round. (see attached pic)
I'm thinking it's time to retire. Your thoughts? And don't laugh.
Ray White
newshirt is offline   Reply With Quote
Old 10-10-2017, 05:38 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: U-joint Play
I don't think I'd retire just because of a bad u-joint, but, that one has seen better days. [ smiley face]
Old 10-10-2017, 05:51 PM   #3
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Looks about ready to blow! Must have been noisey.
Barry B./ Ma. is offline   Reply With Quote
Old 10-10-2017, 06:20 PM   #4
newshirt
newshirt's Avatar
Strangely, I never heard a peep out of it. I'm just going in to change the clutch, which chattered like heck.
Ray White
Old 10-10-2017, 07:07 PM   #5
Anteek29
Anteek29's Avatar
Uh, oh
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 10-10-2017, 08:43 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
You're lucky to live close to Bert's. Go buy a new or good used joint, and clutch parts.
That joint ain't fit for the road, and is way past time to replace it.
Old 10-10-2017, 09:07 PM   #7
goodcar
Ditto
goodcar is offline   Reply With Quote
Old 10-10-2017, 09:25 PM   #8
Synchro909
Synchro909's Avatar
I've heard that the modern replacement unis are not very good even if they fit. Is there another option other than Bert's, like maybe rebuilding them?
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 10-10-2017, 11:09 PM   #9
newshirt
newshirt's Avatar
Steve Becker is sending a good original.
Ray White
Old 10-11-2017, 07:58 AM   #10
KGBnut
KGBnut's Avatar
Mine was a helluva lot worse than that one when I finally replaced it. The two riveted halves were looser, and the bearing surface on one shaft was nearly half gone. It was all caused because I didn't realize just how much of the right kind of grease those things need.
I now carry the worn out one in my trunk for show-and-tell when people ask about repairs and maintenance.
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 10-12-2017, 11:18 AM   #11
abachman3
abachman3's Avatar
Aw come on... run it 'til it's broke!
abachman3 is offline   Reply With Quote
Old 10-12-2017, 12:09 PM   #12
Barry B./ Ma.
Check 29 Cabriolet further down, he did.
Old 10-12-2017, 07:50 PM   #13
glenn in camino
glenn in camino's Avatar
Add lots of grease in the fitting under the U joint.
Old 10-12-2017, 11:34 PM   #14
Tom Wesenberg
For sure! What the heck.........a little play didn't stop this guy.
Old 10-13-2017, 02:46 AM   #15
Christoph
Christoph's Avatar
The rivetet version is not to be rebuilt !!!
Once you see damage , there is no doubt...
Test (if you see no damage):
Hold the U-joint at one end and shake it.
Once it wobbles without resistance and you hear noises....
ITS TIME TO REPLACE !
The "new" parts to be sold by the vendors are not best quality.
(Any new junk will be even better than the ones in those pics.)
Use lots of grease !
Have fun
Chris
I replaced the U-joint in my car with a "new" snyders U-joint 5 years ago.
Even it looked like a strange rough log, its still "alive"
Christoph is offline   Reply With Quote
Old 10-13-2017, 09:57 AM   #16
frank55a
I have a good U-Joint for sale on the Swap Meet page.
frank55a is offline   Reply With Quote
Old 10-13-2017, 10:54 AM   #17
denniskliesen
denniskliesen's Avatar
Victim of grease worms...
denniskliesen is offline   Reply With Quote
Old 10-15-2017, 06:33 AM   #18
KGBnut
KGBnut's Avatar
Tom, mine actually looked a bit worse than that one...
Ken
Old 10-15-2017, 12:09 PM   #19
1crosscut
1crosscut's Avatar
Couldn't be much worse that the one that was in my truck when I found it.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 10-15-2017, 04:25 PM   #20
Synchro909
Synchro909's Avatar
I've just acquired a RHD 1933/4 gearbox (very rare over here) and it has the U joint still on it. Will it fit a Model A? It's not in bad condition and looks like it should fit.
