Old 09-27-2017, 09:44 AM   #1
Scott H in Wheaton
Scott H in Wheaton's Avatar
Default 36 pickup column drop attachment
I did a quick search but didn't see this answered..
Inside the dash where the column drop bolts go through, is there a separate reinforcing plate to install before I put the bolts in?
Just trying to secure the column to get ready for a tow.
Scott H in Wheaton is offline   Reply With Quote
Old 09-27-2017, 09:49 AM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: 36 pickup column drop attachment
I believe there is just the rubber pad there. No extra bracing,
Old 09-27-2017, 10:09 AM   #3
Scott H in Wheaton
Many thanks, you've always been a helpful resource to a fellow '36 owner
Old 09-28-2017, 03:23 AM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
I believe one of my 35 passenger cars had a sheet metal reinforcing plate on the ledge under the dash where the two steering drop bolts fasten and also a rubber pad between the bottom of the dash and the drop mount. Don't know if the pickup's were the same or similar. Maybe others more knowledgeable will chime in.
John
Old 09-28-2017, 03:40 AM   #5
deuce lover
deuce lover's Avatar
Should have a reinforcing plate spot welded to the lip of the dash.
Old 09-28-2017, 04:07 PM   #6
Scott H in Wheaton
The dash is two layers there. I put large flat washers and lock washers under the bolt heads.
