Hi all: I cannot get grease to go into draglink fitting on passenger side. My grease gun is working fine, I removed the zerk fitting and grease passes through it, tried to clean inside of joint with a nail while zerk fitting was off but that made no difference. Anyone run into this before and find a solution?
Thanks |
Did you recently replace your draglink?
Thanks Andy 1952 F1 |
Could you remove the zerk fitting and then insert a flexible piece if stainless fishing line leader to operate like like a Rotor Rooter in an electric drill?
Draglink is original. I guess that trying to remove internal grud is best done mechanically like the roto rooter suggestion. I have read that adding anything other than grease to the joint may be a bad idea. Thanks
If the zerk is bottomed out it will prevent grease form flowing. Back out a little and see if that works. Worked for me.
LockNLube Grease Gun Coupler $29.95
Chisel Evil Lurks...for those that don't carry a side arm!!! |
have someone operate the grease gun while you use a hammer to smack the drag link all the way it, some times the jarring action from the hammer smacks will loosen any old grease in the link and let new grease enter
heat the bottom where it screws in use a heat gun or hair dryer
Remove the draglink and clean it up.
Try some penetrating oil in the end first and let it soak until it comes out the end with the stud. Could also use some K1. I would thing the drag link is at the end of it's useful life.
Thanks to all for your input. I am glad to say that waldo's suggestion worked. Don't ya love it when the solution is that easy. Thanks Waldo.
