Old 04-17-2017, 07:13 PM   #41
Shoebox
Shoebox's Avatar
Default Re: RUNNING HOT..after doing good stuff
OK guys,
Thanks to all who have followed along with this journey and posed some very valid questions and suggestions. Here is the conclusion to this all. I removed the stats and took the Merc for an extended drive on Sunday. The temp was slow to rise (outside temp was 60 degrees) and NEVER got completely to N normal, this was cooler than the past two years of driving this car (Skips pumps work) so when getting back home I let the car idle till the original equipment temp gauge did get to N. I then used my just purchase laser temp gun and shot the upper rad tank and …….. the temp was 155 degrees, this is what N represents on my car! Previously when I drove with the stats and the temp needle went to the ¾ line on the gauge I saw it as running hot. At this point I will reinstall the stats, consider the ¾ line on the temp gauge as NORMAL, and call it good.
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is online now   Reply With Quote
Old 04-17-2017, 07:21 PM   #42
JSeery
JSeery's Avatar
Sounds good to me!
Old 04-17-2017, 07:26 PM   #43
Shoebox
Shoebox's Avatar
I was waiting for ya! "Solving a problem that didn't exist" Your input MOST appreciated.
Shoebox
32 Ford roadster
39 Mercury Towncar
Old 04-17-2017, 09:08 PM   #44
MGG
MGG's Avatar
When I parked my 34 after its first drive it felt hot so I used the wife's meat thermometer in the top of the radiator and got a reading of 200. So, I got new water pumps and had the radiator cleaned and rodded and the engine ran a lot cooler (170 approximately with a laser thermometer). Since then it has never ran as smoothly or as quietly as it did at the 200 temperature.
MGG is offline   Reply With Quote
Old 04-17-2017, 10:00 PM   #45
JSeery
JSeery's Avatar
Did that teach you anything?
Old 04-18-2017, 07:23 AM   #46
chap52
chap52's Avatar
They seem to like that 185 to 200nrange. Just like folks have been saying.
Old 04-18-2017, 04:46 PM   #47
tony starr
tony starr's Avatar
You can always drill some holes in the block if it runs too hot!
Just ask Go Cat Speedshop
tony-starr.com
tony starr is offline   Reply With Quote
Old 04-18-2017, 04:55 PM   #48
Mart
Mart's Avatar
I'd be getting a pipe thread tap and a load of plugs.
Old 04-18-2017, 06:14 PM   #49
JSeery
JSeery's Avatar
That's the air cooled version of the flathead.
Old 04-18-2017, 07:30 PM   #50
Bored&Stroked
Bored&Stroked's Avatar
I gotta ask the obvious question . . . who the Hell did that and for what purpose? Were they running Alky at the drags and thought they'd lose some weight? Do explain! LOL
Old 04-18-2017, 09:05 PM   #51
JSeery
JSeery's Avatar
When we ran a B/A we never ran a radiator. We would fill it with water, seal it up, make a run and then dump the water and refill. I know a lot of engines had the blocks filled solid. I have never seen a block drilled for cooling, but that would be my guess at to what was being attempted.
Old 04-18-2017, 09:14 PM   #52
tony starr
tony starr's Avatar
Here's part of the description that went with that photo from @gocatspeedshop's post on Instagram. Link also below.
I found out from local Drag Racer Wes Johnson that this block was in a '50 Ford Gasser in the early '60s and raced at CDR So the Holes were drilled mainly to cool the block vs weight saving.
https://www.instagram.com/p/BTCHWzUFJsC/
tony-starr.com
Old 04-18-2017, 10:03 PM   #53
JSeery
JSeery's Avatar
Yep, we did some wild things in the 60s. Rear only brakes, no starters, no radiators, etc.
Old 04-21-2017, 10:52 AM   #54
Veeder
Have you retorqued the head bolts? If not I suggest you do it also be sure to back the head bolt off record what it took to break it loose then set it to spec. Worth a shot
Veeder is offline   Reply With Quote
Old 04-21-2017, 11:06 AM   #55
Veeder
Re-torque the heads
Old 04-21-2017, 05:52 PM   #56
Lawson Cox
Lawson Cox's Avatar
Me too.
