Old 04-15-2017, 04:09 PM   #1
Shoebox
Shoebox's Avatar
Default RUNNING HOT..after doing good stuff
So, my 39 Merc cools great, no issues. My passenger side waterpump was flinging coolant, so I did the following: sent the waterpumps to Skip for his well known excellent rebuilds, pulled the radiator and took to the rad shop. When removing the radiator I found there were no thermostats so I got a pair of Shewman high flow thermostats. The shop said the radiator flowed well, no repairs needed, just flushed out thoroughly. So I reinstall all of the above along with new lower hoses and filled with coolant, started her up and if allowed....it will RUN HOT! I have briefly run/driven it an was able to add some additional coolant, I do not believe there is any kind of air in the system. Just came back from brief drive, going to let things cool, and I believe I'm going to pull the stats. What do you guys think??
Shoebox
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 04-15-2017, 04:13 PM   #2
Lawrie
Lawrie's Avatar
Default Re: RUNNING HOT..after doing good stuff
Did the rad shop take the tank off.
Lawrie
Lawrie is offline   Reply With Quote
Old 04-15-2017, 04:31 PM   #3
JSeery
JSeery's Avatar
Also, what are you calling hot? 190, 200, boiling?
Old 04-15-2017, 04:41 PM   #4
Art Newland
Art Newland's Avatar
Probably not, but any chance you put the thermostats in upside-down?
Art Newland is offline   Reply With Quote
Old 04-15-2017, 04:50 PM   #5
Shoebox
Shoebox's Avatar
Thanks for the questions..... no, the shop did not remove the tank. The only temp gauge is the original and previously would not go above "N"ormal. The needle gets to N fairly quick and then moves rapidly higher. The stats are 180 degree. I think this might be the excuse I need to buy a temp gun, but for now that's as precise as I can be.
32 Ford roadster
39 Mercury Towncar
Old 04-15-2017, 04:50 PM   #6
rick r
rick r's Avatar
Suggest that you check the stats to make sure that they are opening. Drill a couple of 3/16 dia holes in each stat. This will allow the air to escape as you are filling with coolant. May run hotter now that you have stats to control the temp. Should run at 185 degrees minimum. Just my thoughts!!!!!!
rick r is offline   Reply With Quote
Old 04-15-2017, 05:05 PM   #7
Ken/Alabama
Ken/Alabama's Avatar
I'm thinking along the same lines as Art. Seen that more than once.
Ken/Alabama is online now   Reply With Quote
Old 04-15-2017, 05:13 PM   #8
Lawson Cox
Lawson Cox's Avatar
You DO have a fan on it don't you? LOL Really, I would think you should have the core rodded out.
Old 04-15-2017, 05:18 PM   #9
Tony, NY
Where did you install the stats? Up by the radiator or down by the head? From my experience, when installed up by the rad it takes a while for the heat to reach the stats to open, so the temp climbs. Unless you have holes in the stats.
Tony, NY is offline   Reply With Quote
Old 04-15-2017, 05:59 PM   #10
Shoebox
Shoebox's Avatar
Again thanks for all the excellent questions. I do have the stats facing correctly, the Shewman stats have 4 small holes, and they (the stats) are located up by the radiator per original. I verified operation prior to installing.
32 Ford roadster
39 Mercury Towncar
Old 04-15-2017, 06:19 PM   #11
Kube
Super Moderator
Kube's Avatar
I believe it always prudent to change ONE thing at a time.
At this point, I'd suggest you remove the thermostats and see the subsequent result.
Do you have a hot water heater? If so, be certain the valve is all the way open. Remove the radiator cap and allow the engine to climb to operating temperature. Then, "rev" it up a bit. Shut it down, allow to cool.
You need to be certain all of the air is out of the system. I've never had a flathead that got air pockets but others have claimed they did. I suppose it's possible.
Check coolant level - should be covering top core plate. Install cap and see what happens...
Old 04-15-2017, 06:28 PM   #12
fordwife
Are you using an original temp. guage? They are not always accurate On my'48 when the guage is 3/4 of the way over, I get 160 to 165 on a laser thermometer. I'm running 160 degree stats.
fordwife is offline   Reply With Quote
Old 04-15-2017, 06:36 PM   #13
51 MERC-CT
51 MERC-CT's Avatar
You say you have Skips pumps.
As I recall in order for his high flow pumps to work properly he says NOT to use thermostats.
Old 04-15-2017, 07:24 PM   #14
JSeery
JSeery's Avatar
Believe he is using the stats GM recommends. Seems to me we are all attempting to solve a problem we don't even know exist. The original temp gauge indication is somewhat meaningless without checking the actual temperature. The question is, how do you know it is overheating if you have no idea what temperature it is running at?
Old 04-15-2017, 07:37 PM   #15
deuce_roadster
deuce_roadster's Avatar
If it isn't boiling over, it isn't overheating has been my experience.
Old 04-15-2017, 07:52 PM   #16
petehoovie
petehoovie's Avatar
What 'deuce roadster' said....
Old 04-15-2017, 08:26 PM   #17
johnny
I also have a 39 Merc. On your rad does the overflow come off a bump on the top centre of the top tank. are you trying to use a 4 pd cap. that combination will not work.The overflow tub should come off the rad neck.
johnny is offline   Reply With Quote
Old 04-15-2017, 08:33 PM   #18
donald1950
have you called Skip to see what he has to say?
and if you remove the radiator have them remove tanks and rod it out. a flow test is not a true indication of how clean the radiator tubes are.....
donald1950 is offline   Reply With Quote
Old 04-15-2017, 08:47 PM   #19
37 Cab
37 Cab's Avatar
I suspect the gauge as well. With no stats and a proper cooling system the gauge should have read cold all the time unless outside temp was above 70. Should have been having trouble getting any heat from heater in cool weather.
Tommy
37 Cab is offline   Reply With Quote
Old 04-15-2017, 10:43 PM   #20
Kahuna
Kahuna's Avatar
I'm with Donald1950 on this one
Kahuna is offline   Reply With Quote
