Old 04-10-2017, 01:55 AM   #6
Beauford
Default Re: 1929 Tudor body on 1931 frame
You will need at least either a 28-29 front crossmember or 1/4 pad (a lot cheaper) under the radiator to get proper alignment. The frame for 28-29 had a raised mounting area on the front crossmember giving the radiator correct height. I may be wrong but I thought I may be in that situation at one time and researched myself.
Beauford is offline   Reply With Quote
