Old 03-14-2017, 07:24 PM   #1
russcc
Default 59AB Fuel Pump stand ?
I would like to remove the steel tube socket for the breather in the fuel pump stand. The tube is steel, the stand looks like pot metal. I was thinking of heating the stand to expand it enough to get the tube out. Any ideas or experiences to share ? Thank you Fordbarners.
Old 03-14-2017, 07:34 PM   #2
bruce lee
Default Re: 59AB Fuel Pump stand ?
I did that and it melted. I ruined the stand but I did get the steel sleeve out to make my 36 breather taller to fit my dual carb high rise set up. It melted really fast so be carefully.
bruce lee is offline   Reply With Quote
Old 03-14-2017, 07:46 PM   #3
J Witt
J Witt's Avatar
Be careful. Not only does the pot metal casting have a low melting point, it is somewhat fragile and can be broken easily if gripped in a vise or such. Also, these are getting to be somewhat pricey.
I recall seeing different fuel pump stands (without a pump flange) in several vendors catalogs. Maybe Speedway, or someone may have a better suggestion.
John
Houston, Tranquility base here. The Eagle has landed.
J Witt is offline   Reply With Quote
Old 03-14-2017, 07:57 PM   #4
Kurt in NJ
Kurt in NJ's Avatar
When I want to remove some pressed in tubing putting a socket or other metal that fits close, then clamp in vice, this way you don't crush the tubing
Old 03-15-2017, 04:53 AM   #5
Mac VP
Mac VP's Avatar
This is the best way we've found. I forgot the size but we used a regular deep socket from the toolbox and slid it all the way in the tube so that it bottomed out against the stand body. Then we were able to grip the thin tube without crushing it, and simply twisted it out. After everything is cleaned up we can reinstall it with some blue locktite.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is online now   Reply With Quote
Old 03-15-2017, 07:27 AM   #6
russcc
Great ideas, thank you. I will try the the interior support, grip it and turn it out method.
