Old 03-11-2017, 08:28 PM   #1
1931flathead
Default tail pipe
were can a buy tail pipe for a 1953 ford car looking for duals
1931flathead is offline   Reply With Quote
Old 03-12-2017, 11:37 AM   #2
toby
toby's Avatar
Default Re: tail pipe
Try: www.waldronexhaust.com
toby is offline   Reply With Quote
Old 03-12-2017, 11:37 AM   #3
1931flathead
I looked on ebay did not find any
Old 03-12-2017, 01:48 PM   #4
rotorwrench
rotorwrench's Avatar
Fords that have the front mounted cross over pipe may require a change of exhaust manifolds to get a better shot for duals. A good muffler shop may be able to form up a set for you but you might have to ask around to find out what shop might be the best bet.
Old 03-12-2017, 01:58 PM   #5
tubman
tubman's Avatar
Decided to pass on the '51, eh? Good choice.
As to tailpipes, I think a stocker will work on both sides. The problem is the exhaust pipe. Unless you do some more changes, it comes off the front of the drivers side exhaust manifold and loops up and back over the steering and dives down under the toeboard. The "Waldron" site mentioned above has a picture of their complete system. The driver's side headpipe is right about in the middle of the picture.
Old 03-12-2017, 02:22 PM   #6
deuce lover
deuce lover's Avatar
EBAY # 381999142719,maybe what you are looking for.
Old 03-12-2017, 02:47 PM   #7
1931flathead
it has header on it so that not the problem
Old 03-12-2017, 02:51 PM   #8
1931flathead
yep I just need the tail pipes only I email him last night
Old 03-12-2017, 02:56 PM   #9
1931flathead
yep got a stock 53 but the headers came south or north Carolina has one small rust spot in the back floor board and a small rust spot in the pas side rocker
I looked on the site and seen it
Old 03-12-2017, 09:52 PM   #10
1931flathead
he got back to me it is 175.00 with shipping
there is a guy does exhaust bending about 40 miles away I heard he does good work and is neat
I had couple done at a shop in town I had a pipe fall of after a week he it weld a quarter of a inch
