#11 | |
When I put hydraulic brakes on a 35, I used Richard Lacy's master cylinder mounting bracket that utilized the stock cross shaft to actuate the MC using the stock brake/clutch pedal assembly. His ebrake hookup was a rather simplified cable that passed through the center of X member in a section of steel tubing, and connected the ebrake lever directly to the ebrake cable that loops around to both rear backing plates, and used the same '39 curved sheet metal bracket like you show in your 3rd picture. Basically a simplified system that utilized stock components requiring no modificatons.
