Old 07-18-2016, 07:08 PM   #1
FortyDave
Default Window regulator install
The door window on my coupe after having a dead spot finally quit. After taking the garnish moulding off I could see what appeared to be baling wire meshed between the regulator and the small gear driven by the crank. I spent a few hours pulling all that wire through the gears so now with no tension from the wire I ordered a small gear repair kit from Drake.
Is there a trick installing this kit leaving the window in or must I pull the regulator ? Any tips most appreciated.
FortyDave is offline   Reply With Quote
Old 07-18-2016, 07:38 PM   #2
johnboy34
Default Re: Window regulator install
Your going to have to pull the regulator out, the small gear is in a little housing riveted on with the crank handle shaft coming out of it also.
johnboy34 is offline   Reply With Quote
Old 07-19-2016, 07:00 AM   #3
FortyDave
Thanks johnboy34
Old 07-19-2016, 07:34 AM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
Replacing windows, regulators, window channels, etc., in these early Ford doors will definitely be a learning experience if it's the first time someone attempts this job. It's not a difficult job, but can be time consuming for someone with little or no experience, but best to go slow and get it done correctly.
John
Old 07-19-2016, 08:08 AM   #5
Robert/Texas
Robert/Texas's Avatar
I spent many hours wrestling with the driver's window in my '37 fordor. After discovering this video I got the window installed in 30 minutes. I know this doesn't help with the regulator problem but hope that it helps with the rest of the job.
Robert
https://www.youtube.com/watch?v=gdcN-ypFNBc
Robert/Texas is offline   Reply With Quote
