#21 |
To allow for a higher lift cam I like them as low as practical.
#22 |
Do you adjust them on the base circle or at top of lift?
#23 |
I would strongly recommend using ONLY the original "Johnson" tappets, they are still available from the same company that began it all. They are all we still use to this day.
I would really be hesitant to use ANY lifter sold as a "Johnson Style", I don't care what anyone tells you about where they were mfd, I wouldn't risk it. For as far back as I can recall we've not had one single lifter complaint, none coming "loose", none "wearing-out", etc., and have sold hundreds upon hundreds. Thanks, Gary in N.Y. P.S. If it helps with the drilling of the block I'll place 2 photos here showing the locations on the bores and the hand drill/bit we use here. It makes the actual drilling really simple! The bits are sort of "flexible" due to the length, never broke one however, just takes some care.
http://www.stromberg-bulletin.com/me...berg-equipped/ |
#24 |
#25 |
Thanks guys. Gary I assume you drill the holes for and aft to avoid drilling over the intake ports?
With cam on base circle the adjuster bolt is partway in the lifter bore, not sure I will be able to get a wrench on it. I have an old motorcycle with the same situation, which necessitates getting on the lobe for wrench room, then turning it back on the base circle to check clearance. This is a V8-60 if that makes a difference. |
#26 | |
Here is another example, but still not squared off. Last edited by JSeery; 03-25-2016 at 04:28 PM. |
#27 |
Ah OK thanks. I saw that in your previous photo but didn't know what it was. The other photos on this thread don't have the reliefs cut. So it's standard procedure, doesn't cause extra wear on the lifter bores?
#28 |
It all depends on the cam you are running. That determines how deep the lifter goes down into the bore. The higher the lift the deeper the lifter will end up in the bore and there comes a point where you need the reliefs to get to the adjuster. All cams start out with the same blanks (this may be over simplified but should be ok for this example). The higher the lift the smaller the base circle ends up and the lower the lifter goes in the bore when it's on the base circle. Thus the need for the reliefs. It is common practice if the cam requires it.
#29 |
OK got it. I'm waiting for my cam to come back from Schneider, then I'll be able to see how much the base circle has been reduced. Thanks!
#30 |
Thanks Gary, Did not know that genuine Johnson was still in production. I am wary of the Johnson style lifters.
The flatattack lifters from Australia were good ,but alas no longer. Though Mike must still have the tooling. Do you have a contact for the Genuine Johnson lifters? Thanks |
#31 |
Chet where in Ma.? i'm in the Lowell area and if you can stop by i'll give you a pair .
#32 |
Good info here guys, but Chet started this thread SIX years ago! DD
#33 |
Make up this wrench drill the holes and all is well no need to scallop the bore.The wrench drops on and doesn't slip.
R |
#34 |
Now that's THINKIN!
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
#35 |
Guess I'm lucky, my neighbor long time parts man local Ford Tractor gave me the
wrench ford script and the holder 'ford scrip' which is one piece with two tangs not the usual two piece. That was late 60's or 70's. All rebuilds they did got adj lifters.. We got all out V8 stuff from them, too bad other went south couple years ago.... All he said back then "remember where ya got it" statue of limitations mine now............ |
#36 |
on new lifters i adjust one then do each one to that length holding them in a vice with soft jaws this way you dont need to turn them as much in block for final adjustment
#37 |
I didn't see where Gofast purchases his original Johnson lifters.
#38 |
I'd like to know this as well. My current choices with my new MAX-1 are butt-grinding a set of NOS Ford lifters (preferred) or using the old heavy lifters that came with the cam. If the stockers don't work out for some reason, I'd like a third choice. I'd like to keep the valve train as light as possible because......well, just because.
By the way "s nichols", knowing the precision that went into the original manufacturing of these engines, that's a real good tip! |
#39 | |
GOSFAST Senior Member Join Date: May 2010 Location: Long Island, NY Posts: 452 Quote: Originally Posted by Ronnie Here u go http://www.toplineauto.com/index.asp http://www.toplineauto.com/about-us.asp http://hylift-johnson.com/our-company/ Find out who sells their product. They bought the Johnson plant and even hired some of the old employee's. R Above here is where we buy the lifters, I'm not sure you can buy direct however!! Possibly, but not really sure? Thanks, Gary in N.Y. P.S. I can tell you when we make this lifter purchase we buy a "tray" at a time to help offset some costs. I believe for the Flatheads there are 96 lifters to one tray, on the Chev's/Pontiac's, etc. we buy 128 lifters at a clip! |
#40 | |
