Old 05-31-2010, 11:01 AM   #1
Chet/Ma.
Chet/Ma.'s Avatar
Default Adjustable lifters
Is there a tool that I can make to stop the lifter from turning while being adjusted? Can someone post a picture?
Or who makes a stop device for this problem? Thanks Chet/ma.
Chet/Ma. is offline   Reply With Quote
Old 05-31-2010, 11:19 AM   #2
Russ/40
Russ/40's Avatar
Default Re: Adjustable lifters
The best solution is to drill a 1/8" hole as low as possible in the boss that the lifter rides in. You then put an allen wrench or such into the hole to hold the lifter from turning. Of course the engine needs to be stripped to do this. Otherwise, buy the "Johnson" tools from one of the major suppliers.
Russ/40 is offline   Reply With Quote
Old 05-31-2010, 11:35 AM   #3
Ed Pitts
Ed Pitts's Avatar
Chet, here are some pics of the Johnson tool. There is a left and a right. Ed
Ed Pitts is offline   Reply With Quote
Old 05-31-2010, 11:39 AM   #4
mfagan
mfagan's Avatar
The drilling the hole method is a much better way to go. In using the manufactured tool method I actually broke the top out of a lifter and found that my flathead buddies method of drilling the hole was much faster and better.
mfagan is offline   Reply With Quote
Old 05-31-2010, 12:19 PM   #5
01aford
01aford's Avatar
Let me begin with. “This is my personal preference”
I don’t like adjustable lifters. Any time there’s a nut it will get loose especially when put under the wear and tear of a lifter. If your valves are cut and fitted correctly at rebuild you won’t have a problem. Don’t get me wrong each one needs to be fit and gapped individually. The adjustable valves correct problems from a less then perfect build.
01aford is offline   Reply With Quote
Old 05-31-2010, 12:23 PM   #6
Don
Don's Avatar
Try your local tractor dealer. Thats where i got mine,not tractor supply, don p
Don is offline   Reply With Quote
Old 05-31-2010, 01:22 PM   #7
Frank Miller
Frank Miller's Avatar
Chet I have the tools and you can have them. Tried a couple and ended up drilling them all. Of course I was assembling the engine and was able to remove them all. If you only need to adjust a few it will not be too bad.
Frank Miller is offline   Reply With Quote
Old 05-31-2010, 04:48 PM   #8
oldford2
oldford2's Avatar
Chet,
How are you doing? Sounds like you are beyond the stage where you can drill the bores. These wrenches are a little tricky but work just fine once you get the hang of it. I can drop a pair in a mailer to you if you want. Just e-mail me. John
oldford2 is offline   Reply With Quote
Old 05-31-2010, 07:13 PM   #9
denverslim
denverslim's Avatar
"Ajustable lifters are made for adjusting". This is exactly what my old rebuilder buddy sez. They make it easier, but not necessarily better...slim
denverslim is offline   Reply With Quote
Old 05-31-2010, 08:04 PM   #10
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Most adjustable lifters are junk now days, made in Kocamumga or some place like that. The adjuster is either to hard to move or there to loose. I don't use them, I butt grind like Henry did. Of course I relize not everybody has valve grinders and butt grinders. If I have to use adjustables I get the ones made in Austrailya (spelling) I know Reds Headers sell them and probably others. They are just like the old Johnson lifters. I just used a set a month or so ago. Every one of the adjustas turned with just the same interfearance. You can use the Johnson type to hold them. The best thing is to drill the lifter boss, but if your engine is all together use the tool. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 05-31-2010, 08:39 PM   #11
denverslim
denverslim's Avatar
Here's a shot of the last engine rebuild I did, showing the holes in the boss' where you can stick in an allen wrench to hold the lifter from turning while adjusting the nut.
I used a little drop of Locktite on each nut just to make me feel better...slim
Old 05-31-2010, 09:32 PM   #12
Chet/Ma.
Chet/Ma.'s Avatar
Default Adjustable lifters From Chet
Thank you, Thank you The block that I was adjusting the lifters had been rebuilt previously and some one did not put the 1/8 holes low enough in all cases. So I got in touch with Joe's Antique and he supplied me with some wrenches. But thank you again for all the help. You guys are always there to help even on a holiday. Chet
Old 03-22-2016, 07:37 AM   #13
chap52
chap52's Avatar
Before install you might carefully place them in a vice (I use a couple of pieces of scrap wood so I don't mess them up). Last set I had the bolts were EXTREMELY tight. A drop of Loctite is a great idea after adjusting.
Lots of great posts on here about sequence and adjusting.
chap52 is offline   Reply With Quote
Old 03-22-2016, 08:17 AM   #14
JSeery
JSeery's Avatar
gclub online
? What does low enough refer to?
Old 03-22-2016, 08:28 AM   #15
Ol' Ron
Ol' Ron's Avatar
All this information and more, is in most of the flathead books, including mine.
Old 03-22-2016, 08:33 AM   #16
Tony, NY
I think he's saying that the holes are low enough in the bosses and should work for tightening.
Tony, NY is offline   Reply With Quote
Old 03-22-2016, 09:19 AM   #17
JSeery
JSeery's Avatar
That's what I was thinking as well but wasn't sure. Might be fine for a stock of mild cam, but I would want them lower in the bosses myself!
Old 03-22-2016, 02:59 PM   #18
jerry shook
I will be putting adj lifters in. My question is what is the best to use.
jerry shook is offline   Reply With Quote
Old 03-22-2016, 03:04 PM   #19
JSeery
JSeery's Avatar
Depends on who you ask! I like the ones Red's sells.
Old 03-23-2016, 06:40 PM   #20
Blowby
BUMP. I have a new set of Red's lifters and bare block. So put the cam on the base circle and measure how far down to the adjuster hole, simple enough. What about locating the holes horizontally, perpendicular to the cam or any old place? The holes in the photo above seem to be random.
Blowby is offline   Reply With Quote
