Old 11-07-2015, 09:46 AM   #4
oldford2
oldford2's Avatar
Default Re: Oil Pump Gasket
Originally Posted by JWL View Post
The gasket thickness controls end clearance and therefore can affect pump performance. The original gasket is not made from a plain sheet of paper. The original is a very thin sheet. I think you will have to search for a proper thickness after checking the clearance needed to allow the rotors to move freely but with minimum clearance.
Jwl,
I think he is talking about the gasket from the pickup to the pump. Not the bottom plate gasket. Thickness is not critical there. JMO. John
oldford2 is offline   Reply With Quote
