Old 11-06-2015, 03:15 PM   #8
rotorwrench
rotorwrench's Avatar
Default Re: how critical is TDC
The crankshaft goes through a fair amount of degrees from the time the piston tops out until it starts going back down. You can use a finger over the spark plug bore to tell that then just a bit more to the timing dot. You might end up one tooth off if you do it too early.
