Old 09-06-2015, 07:07 PM   #2
2manycars
2manycars's Avatar
Default Re: splash shield to running board fitting??
The 30 had a one piece runningboard/splash shield. I dont know how you are going to attach the splash shield, which I presume has been cut from the running board, to the runningboard. If your 30 is a late 30, with the long splash shield and separate running board, then the running board just sits in the U channel of the splash shield. I bet that sounds confusing.
2manycars is offline   Reply With Quote
