Old 07-15-2015, 04:38 PM   #3
JSeery
JSeery's Avatar
Default Re: 6 volt generator
6 volt generators can be converted to 12 volts, but the output amperage goes down. Depending on what you are wanting to do with it that may not be a big issue. You can also have the 6 volt generator converted to a 12 volt alternator.
http://www.btc-bci.com/~billben/6-12volt.htm
