Old 05-29-2015, 07:37 AM   #16
flatheadfan
flatheadfan's Avatar
Default Re: Flex fan?
Kevin-
I understand your thinking but I am not so sure the thrust and/or load change (if any) would be a problem with a replacement fan. As I recall, the Ford standard generator with a bolt-on fan was a four blade critter. A six blade fan (extra cooling), was optional and didn't require a modified or replacement generator to handle the greater thrust/load change created by the heavier fan. Still, you have a point that might enter into the situation and is worth considering.
Thanks
Tom
flatheadfan is offline   Reply With Quote
