Old 05-29-2015, 03:58 AM   #14
koates
Default Re: Flex fan?
You say the fan will be mounted on the generator pulley as on an original 1935 engine. If this new fan has more thrust or load than the original ford fan has then the front generator bearing has to handle this load. Is it a double tapered roller bearing or a ball race ? Just something to think about. Regards, Kevin.
koates is offline   Reply With Quote
