Old 05-22-2015, 07:02 PM   #1
Vanspeed
Vanspeed's Avatar
Default Who makes the best brake light switch?
Ok who makes the best brake light switch? It needs to have the oem style pin connectors on the back. I have heard some horror stories regarding them. Thanks.
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 05-22-2015, 08:03 PM   #2
George/Maine
George/Maine's Avatar
Default Re: Who makes the best brake light switch?
I think that new old stock 6 volt would be the best.
Echlin SL133 now on epay 181572414988 that's is a push in pin
Echlin SL 134 is a push ON type.
Any old stock before 1955
George/Maine is offline   Reply With Quote
Old 05-22-2015, 08:27 PM   #3
Vanspeed
Vanspeed's Avatar
I heard nos ones quit pretty quickly with silicon brake fluid?
Old 05-22-2015, 10:40 PM   #4
fordor41
fordor41's Avatar
"the best" probably is a relative term. Depends on manufacturer, type of fluid possibly and am't of use. If your car gets driven once a month any switch probably will last a long time and if it's driven constantly it MAY also last forever. Personally I've never had a brake switch fail and I have 250K miles on my '41 Ford. I think my switch came from Mac's 20 yrs ago and I've used it with standand bulbs, halogen and LEDs. It's probably like every thing else, some are good and some are just better
fordor41 is offline   Reply With Quote
Old 05-23-2015, 02:21 AM   #5
deucemac
deucemac's Avatar
I had 3 fail until I went with a Harley switch. Original style switches DO NOT like silicone fluid. The terminals are of the spade design and it is very easy to convert.
deucemac is offline   Reply With Quote
Old 05-23-2015, 06:31 AM   #6
George/Maine
A lot of people go to mechanical switch they were very common on 50s Chevy.
very easy to buy Speedway NADA 1952 Chevy switch.
Old 05-23-2015, 06:41 AM   #7
john in illinois
john in illinois's Avatar
This switch sounds interesting,but I have no experience with it.
http://www.ecihotrodbrakes.com/inlin...ht_switch.html
John
john in illinois is offline   Reply With Quote
Old 05-23-2015, 07:37 AM   #8
flat 39
flat 39's Avatar
After 2 of the cheap $6 ones, I have had success with Motorcraft brake switch.
flat 39 is offline   Reply With Quote
Old 05-23-2015, 10:18 AM   #9
mike in las vegas
mike in las vegas's Avatar
I echo what deucemac says. No problem with Harley switch using silicone fluid.
mike in las vegas is offline   Reply With Quote
Old 05-23-2015, 12:28 PM   #10
BlueSunoco
Same here you can still get them from your Ford dealer sorry I don't have the part number been too long ago since I made the 'switch'.....get it
BlueSunoco is offline   Reply With Quote
Old 05-23-2015, 01:48 PM   #11
Henry Hopper
Henry Hopper's Avatar
Ford.
Henry Hopper is offline   Reply With Quote
Old 05-23-2015, 06:08 PM   #12
Vanspeed
Vanspeed's Avatar
I think I will just order one from Mac's. It is going to be driven regularly so hopefully I will have no issues. Does anybody make the female connector that is part of the harness that connects to the switch? Mine kinda crumbled when I took them off.
