Old 12-30-2014, 03:54 PM   #1
Tod
Default New Winfield update
I forgot to let those interested know that I have the Winfield core plug all cut and have test fit it in the foundry mold. It fits perfectly. I discussed cores with the new core shop I plan to use for these. I hope to keep thing on track for getting castings some time in January. But it will depend on how quick the core shop can produce them. If you would like to get in on the first run of these 6:1 heads let me know. Several people are already on board.
Tod
Tod is offline   Reply With Quote
Old 12-30-2014, 07:40 PM   #2
waxhead
waxhead's Avatar
Default Re: New Winfield update
Thanks for the update Tod.
waxhead is offline   Reply With Quote
Old 12-30-2014, 09:11 PM   #3
a-bone newby
a-bone newby's Avatar
hi how much and where are you shipping from as shipping costs can bury me in northern b.c. canada
a-bone newby is offline   Reply With Quote
Old 12-31-2014, 09:50 AM   #4
gz
gz's Avatar
I probably missed reading about this in other posts. Is this a cast iron Winfield head that looks just like the original cast iron Winfield? If so, put me down for one. Great project. Thanks.
gz is offline   Reply With Quote
Old 12-31-2014, 10:46 AM   #5
Tod
Yes it is.
Tod
Old 12-31-2014, 11:07 AM   #6
M2M
M2M's Avatar
Can someone post a pic of an original cast iron Winfield head?
M2M is offline   Reply With Quote
Old 12-31-2014, 01:00 PM   #7
Juggler
Juggler's Avatar
This one is my one
Juggler is offline   Reply With Quote
Old 12-31-2014, 01:20 PM   #8
hardtimes
hardtimes's Avatar
Originally Posted by Tod View Post
Yes it is.
Tod
Hey Tod,
Thanks for posting update ! Yup, still in line, but for 8:1 !
This is for the 'CROWS FOOT' chamber...correct ?
Good to know that you are not frozen solid with all the climate warming thing going on !
Also, hope you got all of you BIG machines back on line.
Finally, anything going on with block project ?
Old 12-31-2014, 01:32 PM   #9
Juggler
Juggler's Avatar
This is the other side of mine, before and after
P1100061 by juggler29, on Flickr
P1100275 by juggler29, on Flickr
Old 12-31-2014, 02:36 PM   #10
edmondclinton
Looks like it's cracked from the center oblong water hole over to the round hole near it on the side opposite the dist. side.
edmondclinton is offline   Reply With Quote
Old 12-31-2014, 02:47 PM   #11
Tod
In that area I have added a rib that supports the deck against the top of the casting. There are other strengthening ribs added also.
Tod
Old 12-31-2014, 03:01 PM   #12
Binger
Binger's Avatar
Here is a couple of pictures of my Super Winfield head. Its a little different than many I have seen. I think its about 8:1. Have any of you seen a super that is cast iron and has such small combustion chambers?
Binger is offline   Reply With Quote
Old 12-31-2014, 03:07 PM   #13
Tod
I couldn't get the bottom 2 pics to open up.
Tod
Old 12-31-2014, 03:25 PM   #14
Binger
Binger's Avatar
Here are those pics again. I must have somehow loaded thumbnail size ones initially.
Old 12-31-2014, 04:44 PM   #15
Tod
How deep are those chambers?
Tod
Old 12-31-2014, 05:19 PM   #16
Binger
Binger's Avatar
They are only about 1/2" deep.
Old 12-31-2014, 05:52 PM   #17
hardtimes
hardtimes's Avatar
Hey Binger,
Yeah, that chamber looks like my super Winfield aluminum head.
If yours is an original windield...look closely on the 'pad', as I understand that Winfield had the comp ratilo stamped on that pad ?
Here's my aluminum Winfield
The valve pockets have been modified slightly to ensure that large valves (1.75") will work with this super Winfield. But, I'm holding off using it, as I'm waiting for Tods IRON copy with crows foot chambers...which You and I do not have on these two heads , BUT Juggler does have !!
Old 12-31-2014, 06:05 PM   #18
edmondclinton
Tod
They'll all crack there if they get hot enough. Ribs sound good but may impede the flow of water. There's already plenty of columns for the water to have to flow around as it is.
Old 12-31-2014, 06:10 PM   #19
hardtimes
hardtimes's Avatar
Tod
Uh-huh, more ribs please, well done ! AND, thicker deck too, so that cr can be increased if wanted !
Old 12-31-2014, 06:33 PM   #20
edmondclinton
Yup, and less water volume flowing as a result of a thicker deck than the original manufacturer intended and along with more obstructions, known as ribs.
The truth is, no one knows how the head will work exactly until it is proven in the field.
