Did the F1 Ford pickups have a factory radiator fan shroud?
Son, you will never blow an engine up in high gear. |
Been through 5 f-1s with both in line 6 and v-8 . Not seen a shroud on any of them. I ask the same question and was told by some old timers (older than me
that at that time every effort to make an economical vehicle was put in to the pick up truck line. Such as only 1 wiper and 1 door key lock.
Yes they did, I have three for the inline six, If anyone needs one
I have one that came out of a F2 with a V8. I can provide measurements if anyone wants to know if it will fit a F1.
The F2 radiator has a flange on each side of the core that the shroud bolts to. If the F1 has the flange, It could be an indication that it was equipped with the shroud. |
Yes, here is one. Bill Boomer (4tford) got it for me out of a grain truck up in Saskatchewan. Not a great pic. Yes they bolt to the flange on the radiator.
'52 F-1, EAB flathead |
That's the one.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. " |
Our '51 F-1 V8 has a fan shroud and, most of the F-1's I've seen have them as well.
Imagination is more important than knowledge. |
#9 | |
You've got to watch those "old timers". The 1 door key lock was a safety issue as Henry didn't want you to enter/exit or stand in traffic unlocking your door. You had to get in from the curb/sidewalk. As far as one wiper, I went to the bother to hook up the second wiper on my 48 and found the linkage binds, causing more drag so I disconnected it. For 10 years of daily driving, I ran just one - the cab is narrow enough it's all you need. Also keep in mind this was post-war. Chrome and stainless steel was abundant for civilian products again. These trucks came with a lot more shiny stuff than the 42-47's, so it wasn't all about keeping things cheap. To the OP question, yes the F1's came with shrouds because they had the same cooling needs as big trucks. Later owners became lazy when they had to change hoses or waterpumps and eliminated them when replacing parts. Which in part, lead to people complaining that "flatheads run hot". If you have one, use it. If you don't, find one and reduce coolant temps - and not just the shroud, but the in hood deflector and the gravel pan. |
PM sent. Thanks. Steve
If it aint broke, don't fix it! |
There are radiator shrouds on my F-1 (8 cylinder) panel truck and the F-3 (226 inline six).
#13 |
I just picked one up or my 48 v-8. Mine was missing, typical of farm trucks. I also suspect owners left them off after servicing the waterpump or something to make it easier on them. Almost all the trucks I see "in the field" are missing them as well.
Respecting and Resurrecting Ford Model A's. |
#14 |
MT has it right. They all had shrouds and the lower gravel pans. Most disappeared because of the pain to service the lower hoses, pumps, etc....
Barry 50 F-1 |
#15 |
Not to mention the hassle of getting the fan lined up in the center without it hitting the shroud. Life is so much easier without that thing.
#16 |
Need shroud for Ford F1 pickup 1948. Call Gary 502-292-7470. Thanks.
#17 |
Anyone have a line on a fan shroud that would fit a 49 F-1 V8?
#18 |
I got one from fordyford awhile back for my '48 F-1.....
it's possible he may have another. 36 cord also told me he had one. |
#19 |
Thanks, I'll see if I can make contact
| Thread Tools | |
| Display Modes | |
