Old 05-15-2013, 08:12 PM   #1
KiWinUS
KiWinUS's Avatar
Default help 33 engine id ?
Guys I drug a "33" engine home tonight , realy dont know what it is , has 33 style clutch 46 intake 33 oil pan painted greeen & been sitting for 30 plus years anu ID clues before i dissmantle much appreciated
Thanks
Cheers
Tony
Old 05-15-2013, 09:14 PM   #2
mfagan
mfagan's Avatar
Default Re: help 33 engine id ?
No pictures...
mfagan is offline   Reply With Quote
Old 05-15-2013, 09:45 PM   #3
David J
David J's Avatar
Pull up the block ID thread by 38coupe . Should answer all your questions .
Thanks
Cheers
Tony
David J is offline   Reply With Quote
Old 05-16-2013, 06:53 AM   #4
jimTN
33-5 all are basically the same block. Later blocks have the breather tube in the valve valley. If I remember right, pan did not change until the block with the breather tube.
Old 05-16-2013, 08:21 AM   #5
DavidG
DavidG's Avatar
I believe that you meant '33-'34 blocks. '35 blocks are vented as are their oil pans.
Old 05-16-2013, 10:57 AM   #6
KiWinUS
KiWinUS's Avatar
Thanks for all the help guys , its a 33-34 then as the pan or block(pulled intake last night) not vented .
Thanks again !!
Cheers
Tony
Old 05-16-2013, 11:08 AM   #7
deuce lover
deuce lover's Avatar
Seen an early 33 block which was just like a 32(no cavity between water inlet and timing cover) , the petcocks were angled and not straight down.
Old 05-16-2013, 11:39 AM   #8
Andy
Late 32 engines used the identical steel pan as the 33-34 engines except for the dip stick boss. Check your engine for straight down water drains. You might get lucky.
Andy is offline   Reply With Quote
