Old 03-19-2026, 04:04 PM   #41
19Fordy
19Fordy's Avatar
Default Re: 40 Ford drop axle
I don't recall if I said earlier that I had to shorten the drag link about 3/4 inch because the Magnum axle is 3/4 in. narrower than stock
Old 03-20-2026, 06:05 PM   #42
Sid
Sid's Avatar
Yes you did. I only dropped 1 1/8 beyond stock so my drag link is good as is. Even the tie rod was good as was. I will double check that though when I drive the car and put on the lift. Car sets pretty good. About 25 1/2 from ground to fender lip. I would sure like to put on some white walls but having a hard time justifying nearly $1100.00.
Sid is offline   Reply With Quote
Old 03-20-2026, 06:15 PM   #43
petehoovie
petehoovie's Avatar
Old 03-21-2026, 10:27 AM   #44
19Fordy
19Fordy's Avatar
Your 40 sits right and looks good. With enough fender clearance you are "good to go".
Nice to see your door handles are straight.
Old 03-21-2026, 11:49 AM   #45
TJ
TJ's Avatar
Sid you car looks good and really sits just right. I think if you purchased whitewalls today you would find that $1100 would be a steal. I like black walls and they look great on early V-8s.
TJ is online now   Reply With Quote
Old 03-29-2026, 05:49 PM   #46
Sid
Sid's Avatar
I found some white walls on evilbay at a decent price. ($480.00) Not real wide as they are just a hair over 1 1/2". Less then half the price of the wider ones. I think it brightened thing a little. Not a great pic as it is still stuffed in the shop.
Old 03-29-2026, 06:37 PM   #47
petehoovie
petehoovie's Avatar
I think it looked better with black walls...
Old 03-29-2026, 08:33 PM   #48
19Fordy
19Fordy's Avatar
looks great
Old 03-29-2026, 08:36 PM   #49
tubman
tubman's Avatar
Originally Posted by 19Fordy View Post
looks great
I think so too. Some cars, including '40 DeLuxe coupes, look better with whitewalls. It's got to do with the innate "flashiness" of the design and sometimes the color.
Old 03-30-2026, 05:49 AM   #50
glennpm
glennpm's Avatar
Great look
