Old 02-03-2026, 12:45 AM   #1
Sid
Sid's Avatar
Default 40 Ford drop axle
I am thinking about sending my axle to Oakie Joe to have dropped. I dont want to go 4''. I am figuring about 3'' to 3 1/4''. Just not a fan of the fender lip even with the spindle. S the question is what are you guys doing about steering arms? I have heard 40 Ford arms are a little too short to heat and bend. I prefer to use the stock tie rod ends as opposed to drop thru bolt. Where are you folks getting your arms and any part numbers would help.
Sid is offline   Reply With Quote
Old 02-03-2026, 06:52 AM   #2
alchemy
alchemy's Avatar
Default Re: 40 Ford drop axle
The actual drop is not 4 extra inches on a 4” dropped axle. Only about 2 to 2.5. Any hot rodder worth their salt can drop the stock steering arms that much. You could also taper the tie rod holes half way from the other direction if you want to flip the tie rod over for needed clearance.
You might want to read up on who has the best reputation for good work before sending off your axle. And that’s all I’m gonna say about that.
alchemy is offline   Reply With Quote
Old 02-03-2026, 09:11 AM   #3
rich b
rich b's Avatar
If you don't care to or are unable to rework the stock steering arms; the other axle guy can drop your axle and rework your spindle arms to match.
rich b is offline   Reply With Quote
Old 02-03-2026, 09:12 AM   #4
sidevalve8ba
sidevalve8ba's Avatar
You might want to watch this video.
https://www.youtube.com/watch?v=yNSAxXsZl7k
Cars are like potato chips, its hard to have just one.
sidevalve8ba is offline   Reply With Quote
Old 02-03-2026, 10:12 AM   #5
V8 Bob
V8 Bob's Avatar
Very good video. Thanks.
V8 Bob is offline   Reply With Quote
Old 02-03-2026, 10:32 AM   #6
19Fordy
19Fordy's Avatar
Thanks for posting that dropped axle video. Sid and his team sure are masters of their craft. Had no idea dropping was such an art combined with skill.
Old 02-03-2026, 11:00 AM   #7
Zax40
Zax40's Avatar
Send your spindles with the axle when you have it dropped. They should be able to do both.
Zax40 is offline   Reply With Quote
Old 02-03-2026, 11:37 AM   #8
Sid
Sid's Avatar
I'm only going to drop about 1" from stock. I have heat and bent steering arms on model A's and 32/36 arms. I've used Oakie Joe in the past and had him drill axles. Did a good job. I've seen new dropped steering arms. Just wondered if it is a better way to go. I was figuring buying his core.
Old 02-03-2026, 11:54 AM   #9
TJ
TJ's Avatar
Great video. A time consuming process to do it right.
Old 02-03-2026, 12:51 PM   #10
Sid
Sid's Avatar
What size tires are you folks generally using with your dropped axles? are you stretching the axle or are you guys letting the axle suck in? I'm running brake drums as opposed to disc.
Old 02-03-2026, 01:44 PM   #11
petehoovie
petehoovie's Avatar
Old 02-03-2026, 02:41 PM   #12
flatford8
flatford8's Avatar
That’s a pretty car!……Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
flatford8 is online now   Reply With Quote
Old 02-03-2026, 03:18 PM   #13
alchemy
alchemy's Avatar
Let the dropped axle suck in and it will give you more tire clearance.
Old 02-03-2026, 04:27 PM   #14
Sid
Sid's Avatar
Thank you.. I was thinking the same thing. Right now it is 26 1/2" from ground to bottom of fender lip.205/75/15 tires on 5" wide rims. 1" more then stock might work. Putting tire just a tad above fender lip.
Old 02-03-2026, 09:32 PM   #15
19Fordy
19Fordy's Avatar
My 4 in. dropped axle is 3/4 in narrower than stock for better fender clearance. However, that increases the turning radius.
Old 02-04-2026, 01:14 AM   #16
petehoovie
petehoovie's Avatar
Old 02-04-2026, 10:47 AM   #17
Tim Ayers
If you look at Greg Anson's site, he talks about why he does reduce the eye to eye measurement for this reason and keep the tracking/width correct.
Old 02-04-2026, 11:01 AM   #18
Sid
Sid's Avatar
Thanks 19Fordy.. What size tire are you running in front? I may need to go down 1 size.
Old 02-04-2026, 04:04 PM   #19
19Fordy
19Fordy's Avatar
Sid , this thread has the tire info. you requested.
https://www.fordbarn.com/forum/showt...=261133&page=2
Old 02-06-2026, 09:26 AM   #20
pistonbroke
I bought the bolt on arms for my 41 pickup. They were an easy way to go and avialible in one to four inch drops. Tim
pistonbroke is offline   Reply With Quote
