Old 03-29-2026, 08:43 AM   #41
glennpm
glennpm's Avatar
Default Re: Original 1932 frame and repo body
Originally Posted by PeteVS View Post
I know I've read it in the past (I forget where) but original frames were subject to being bent. If a driver has a tank full of gas and a spare tire mounted back there, all of that weight is hanging out there a good distance from the rear crossmember. Traveling at a good speed and hitting a significant bump will create enough of a bending moment on the frame to bend it.
My frame had this issue. Just under the frame bend, the sides of the frame bulge out a bit from the downward bending from the loads you mention or from being hit in the rear.
Old 03-29-2026, 10:58 AM   #42
Harold Degand
I’m curious to know how you did.
I tried without heating, the frame didn’t bent.
Harold Degand is offline   Reply With Quote
Old 03-29-2026, 11:32 AM   #43
glennpm
glennpm's Avatar
You need an Acetylene-and Oxygen rose bud flame and work back and forth between the two rails until you have a dull red color. No way to do this with a press or with hand tools with an assembled frame. The metal has stretched and yielded.
Old 03-29-2026, 11:54 AM   #44
rotorwrench
rotorwrench's Avatar
Looking at photos is not best way to judge but it looks to me like the lower curve on the body behind the B pillar is a tighter curve than that of the original body. It would be interesting to compare a correct quarter panel to that Swedish type. If the doors fit and the upper belt line is correct in contour then that would be major surgery to get that rear kick up curve back where it would need to be. An inch off would be noticeable. messing with the floor may pull the belt line out of contour.
rotorwrench is online now   Reply With Quote
Old 03-29-2026, 02:00 PM   #45
Harold Degand
With the doors on.
The belt line looks good
Old 03-29-2026, 02:04 PM   #46
Harold Degand
This one is built by the customer. Almost no gap on the rear.
Most likely the jig they use isn’t correct
Old 03-29-2026, 02:21 PM   #47
petehoovie
petehoovie's Avatar
Originally Posted by Harold Degand View Post
With the doors on.
Old 03-29-2026, 02:22 PM   #48
petehoovie
petehoovie's Avatar
Old 03-29-2026, 03:58 PM   #49
kurt v
I know nothing about this body and frame but would fitting the firewall and feet pick the noes up and tip the rear down ?
kurt v is offline   Reply With Quote
Old 03-29-2026, 04:48 PM   #50
Flathead Fever
Flathead Fever's Avatar
I have an unfinished Boorkville body sitting on a nice original late model original frame. At first, it was sitting too high but then I slid it back a little bit and boom it fell down onto the frame. it's a tight fit. It was such a tight fit onto the frame that just being off a little bit made all the difference.
I have another '32 frame without the factory rear reinforcements to prevent the horn from settling down. It had bent down rear horns. I made a templet from my perfect frame. I laid the frame on the ground and stuck about a 1000 lbs. of block on the rear of it and heated the rear kickups where they were bulged out from the rearend hitting them. Then I took a floor jack and jacked the frame horns up until they matched my templet and I tapped the bulges back in. Then I built my own reinforcements similar to the late model '32s. Most of those early frames without the reinforcements I've seen have sagging rear frame horns and frame bulges. Before you mess with them make sure the body is lined up so it fits all the way down onto the frame.
Your frame including the firewall should fit flush onto the frame with just the thin frame webbing between the frame and body. At least that's what I remember since my stroke. could be wrong, I'd verify that. I'm doing a '34 pickup and it has wooden body blocks but if I remember correctly the '32 cars don't use blocks. I don't trust my memory since my stroke; The auto parts stores sell a box of different thickness alignment shims that work well for slipping between the frame and body to get the doors to fit. I bolted the four corners of the body to the frame and then jack the center of the body up until the doors were level with the quarter panels and slid some shims between the frame and body. It worked really well.
Old 03-30-2026, 05:45 AM   #51
glennpm
glennpm's Avatar
Yes, this is correct. The replacement floor shape and edge reinforcement are not following the frame contour. The floor should mimic the frame contour all the way back to the kickup for the gas tank.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 03-30-2026, 05:52 AM   #52
Mart
Mart's Avatar
32s don't use rectangular tube subrails. The floor needs some reworking to sit down lower over the frame and follow the contour more closely.
Old 03-30-2026, 05:59 AM   #53
glennpm
glennpm's Avatar
Proper floor
Old 03-30-2026, 11:59 AM   #54
Flathead Fever
Originally Posted by oldford View Post
I wonder how well the Brookville roaster bodies fit.
I have a Brookville body and every bolt hole on an original frame lined up perfect with the repro body mount holes. It was a tight-tight fit over the frame. At first, I thought it didn't line up but then it just fell into place. I'm picky about stuff but I don't think you could buy a better reproduction. It still needed a lot of block sanding to get the waves out of the sheet metal but overall, I was happy with it. I inherited my dad's real '32 roadster so I have a real and a fake body to compare to each other.
Old 03-30-2026, 04:19 PM   #55
Karl Wescott
Karl Wescott's Avatar
IIRC, a post in an old thread by Dave Rehor, he mentioned that 1/8" pads were used front to the last from the rear, the rear body mount had a 3/16 or 1/4 pad.
Karl Wescott is offline   Reply With Quote
Old 03-30-2026, 05:17 PM   #56
oldford
Gap on a coupe body is larger than 3/8". If it was 3/8 the front edge of the gas tank would hit the floor pan.
oldford is offline   Reply With Quote
Old 03-31-2026, 09:44 AM   #57
Harold Degand
We had contact with the company who built the body.
They said the issue is because I use an european frame.
I’ve never heard there is difference between european and american frame !
Old 03-31-2026, 10:20 AM   #58
glennpm
glennpm's Avatar
There is no difference. The '32 frame had various hole drilling, crossmember differences and rear reinforcement but the curvature and body mounting was all the same.
Ask them for their drawing :-)
Rumble Seat’s Notes
Old 04-07-2026, 11:52 PM   #59
Harold Degand
Here you can see the manufacturing of their bodies : https://www.usabil.nu/reportage/usab...-del-4-kaross/
Look at the height of the rear kick up. No more to say.
Old 04-08-2026, 01:08 AM   #60
petehoovie
petehoovie's Avatar
