Old 03-20-2026, 06:05 PM   #32
Sid
Sid's Avatar
Default Re: 40 Ford drop axle
Yes you did. I only dropped 1 1/8 beyond stock so my drag link is good as is. Even the tie rod was good as was. I will double check that though when I drive the car and put on the lift. Car sets pretty good. About 25 1/2 from ground to fender lip. I would sure like to put on some white walls but having a hard time justifying nearly $1100.00.
Sid is offline   Reply With Quote
