Old 08-27-2024, 08:31 AM   #21
deuce lover
deuce lover's Avatar
Default Re: No spark to plugs
To quickly check your coil ,if you hadn't .On a continuity check with a multimeter put the red probe on the + and the black on the -. If you get a reading its closed or good,if not its an open circuit so no good.
Old 08-27-2024, 08:42 AM   #22
FrankWest
FrankWest's Avatar
There is continuity. My lights still work, but my horn sounds a little muffled, not strong. Could I have a short in my wiring that is sabotaging the entire system.
The entire car wire harness is less than 10 years old. I bought a high quality wire harness., from New England harness I think was the name. It was very high quality wiring and expensive.
FrankWest is offline   Reply With Quote
Old 08-27-2024, 08:53 AM   #23
rockfla
rockfla's Avatar
Does your battery cable arc or hear it snap when you put it back on? ALSO you can remove your ground cable and use your multi meter between the cable end and touch the other end to the battery post. IF you get a reading you know you have a open ground somewhere.
Old 08-27-2024, 09:24 AM   #24
FrankWest
FrankWest's Avatar
no snap heard.
I removed the ground cable from the battery. Now I test for continuity between the ground cable and the positive battery terminal
My starter works fine.
Old 08-27-2024, 09:41 AM   #25
rockfla
rockfla's Avatar
no snap heard.
Your not checking for continuity, you need to be checking to see IF there is "voltage" flowing from the battery to ground. Even if you have an open ground, everything will still work as it should Frank. IF you get a reading on your multi meter from the ground cable to the post then something some where is grounding.
Old 08-27-2024, 09:43 AM   #26
FrankWest
FrankWest's Avatar
Ok, I will also try jumping my key switch, maybe the switch broke and is not turning the car on anymore.
Old 08-27-2024, 09:54 AM   #27
rockfla
rockfla's Avatar
That is an easy test, you can check to make sure you have 6V + going into the switch THEN switch the car on and check the "out" terminal and you "should" see the same voltage.
Old 08-27-2024, 11:11 AM   #28
drolston
drolston's Avatar
I can't read any voltages out of my coil. Could a bad condenser knock everything out?
Step 0 was to check if you had voltage to the input to the coil and if not to work your way through steps. You just said you can't read any voltage "out of the coil" Does that mean no voltage at either the + or - terminal?
Old 08-27-2024, 11:27 AM   #29
FrankWest
FrankWest's Avatar
yes
Old 08-27-2024, 11:30 AM   #30
FrankWest
FrankWest's Avatar
strange twilight zone stuff.
I have lights, muffled horn, good starter action.
i though maybe the key ignition switch and on lever are caput.
Old 08-27-2024, 12:00 PM   #31
FrankWest
FrankWest's Avatar
I jumpered the key switch and my car amp meter started registering.
not with starting but when i turn the lights on and off. Now the kicker, I removed the jumber and the ammeter is registering with lights and horn. Where is rod serling when you need him.
Old 08-27-2024, 12:03 PM   #32
FrankWest
FrankWest's Avatar
Maybe the car ammeter was stuck and jumping the leads freed it up
Old 08-27-2024, 01:11 PM   #33
FrankWest
FrankWest's Avatar
Now when I press the starter, the ammeter jiggles. I was told this jiggling is the points opening and closing? Is that true? Now maybe the problem is in the distributer itrself?
