Old 05-17-2021, 03:26 PM   #1
WABOOM
WABOOM's Avatar
Default Leaf spring eye bolt '51 Merc
I'm putting new leaf packs (McVeighs) on my 51. I didn't know that the front leaf spring hanger bolt is a forged rivet that needs to be wrecked and replaced. A replacement bolt is not easy to find on the internet. In fact info on this is pretty light in my research. Anyone here ever weld the original on back into the hanger bracket?
WABOOM is offline   Reply With Quote
Old 05-17-2021, 04:38 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Leaf spring eye bolt '51 Merc
Replaced my springs years ago.
As I recall, after removing the nut, soak the inner and outer areas with penetrating oil.
Then the bolt gets driven or pressed out from the threaded end.
As I recall the bolt is an assembly that has a large attached washer on the outer end.
Old 05-17-2021, 05:50 PM   #3
19Fordy
19Fordy's Avatar
If you have access to a lathe you can make those bolts. That's what I did. You might be able to modify a standard bolt if it has a long enough shank size.
Old 05-17-2021, 06:02 PM   #4
rotorwrench
rotorwrench's Avatar
I imagine that it might be necessary to destroy one or two to get them out. They can get pretty crusty. I would check with Southside Obsolete for the 8M-5630-A or 0M-5630 shackle kits.
Old 05-17-2021, 06:55 PM   #5
WABOOM
WABOOM's Avatar
Thanks for the replies. I've got everything apart except this bolt. Not very crusty.
So the washer on the threaded end comes off and then drive the bolt out like kind of like a modern wheel lug stud?
Old 05-17-2021, 07:14 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
Believe the washer stays in place.
Protect the threaded end and drive/press it out.
Old 05-17-2021, 08:16 PM   #7
WABOOM
WABOOM's Avatar
Thank you.
Old 05-17-2021, 08:40 PM   #8
53Customline
53Customline's Avatar
I was able to find those bolts NOS for my 53 Customline.
I think from Carpenters.
53Customline is offline   Reply With Quote
Old 05-17-2021, 09:34 PM   #9
51 MERC-CT
51 MERC-CT's Avatar
Macs apparently has them see here---------
https://www.macsautoparts.com/rear-l...9-19386-1.html
Carpenter out of stock
Old 05-17-2021, 09:38 PM   #10
19Fordy
19Fordy's Avatar
Wow, that's a great find. Wish I had known.
Old 05-17-2021, 10:08 PM   #11
WABOOM
WABOOM's Avatar
Well damn. I searched using Bing and Google, and that never came up as a result. Thanks again. I'm ordering them.
Old 05-18-2021, 12:37 PM   #12
rotorwrench
The 8A part number will fit the Fords and later 52/53 Mercury but I don't know if it will fit the 49 through 51 Mercury. The 49/51 Mercury cars had it's own part number 8M-5780-A. The length or pin diameter may be different. The 1949/51 Mercury also has its own bushings by part number.
General spring shows shackle kits for 49/51 Merc but no photo. Jamco Suspension sells the rear spring front single pin kit. They do a lot of custom stuff for Mercs.
https://www.jamcosuspension.com/prod...wbolt-flb4951m
FCRC machine also sells them and may be the manufacturer.
http://fcrcmachine.com/rare-parts-re...mercury-35590/
Old 05-18-2021, 10:19 PM   #13
WABOOM
WABOOM's Avatar
I got one side off. This bolt is useable as is. It was a bit of a struggle getting it out. The bushing was all swelled up from the squaw piss (P.B. Blaster).
Old 05-18-2021, 10:24 PM   #14
tubman
tubman's Avatar
Good work. If you ruin the other one getting it out, you have a pattern from which to build a replacement. (When I was a kid, we made stuff like that from standard hardware store parts, my old man's drill press, and a couple of files.)
Old 05-18-2021, 11:00 PM   #15
WABOOM
WABOOM's Avatar
Absolutely! I did order a couple from Mac's though. But by the time they get here I'll probably be rolling again. I am a lathe machinist by trade so making one wouldn't be a big deal but for $25 I figured I'd spend my lunch break eating lunch. Lol
