#21 |
The bottoms of my doors are horrible.
I try not to look too closely and just drive it. |
#22 | |
#23 |
Cab corners ,cowl panels, and the floor pans are the common rust area. If it has a heater(or had a heater) pay close attention to the passenger side floor pan.
#24 |
Add to those, around the windshield, fender extensions, fenders where the running board attaches, and the running boards themselves. All good fun.
Bruce
Works good Lasts long time |
#25 |
Yeah, I know what you mean, "the voice of reason".... hahaha
Rust out spots really depends on the area you buy your truck from. Mid-west and south can be really bad, north west US varies, southwest US is usually solid.... Most I've seen rust out where the lower valance meets the front fender extensions - below the headlight. The metal bed floor can rot depending on how the truck was cared for. Plus what the others have mentioned. |
#26 |
For the 53-56 trucks, the cab roof by the rain channel, the front of the hood, and the side cowls are watch areas.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
#27 |
Went and took a good look at the 49 over the weekend. Gonna bring it home next weekend.
Couldn't find any rust except for the drivers side floor boards. Should be an easy fix. The truck needs a lot of mechanical repair, no brakes at all, the wiring harness is a DIY setup that's in good shape but I'll want to put it back stock, has been converted to 12 volts however. The engine appeared to have a considerable amount of blow-by, my first flatty V8, I'll have lots of questions.
#28 |
Yup. That looks sharp.....
AFA answering questions, I only know a little from what I've gleaned owning mine for 1.5 years but I'm game. |
#29 |
Art,Here's cuz to your truck... Lot of F-1 guys and experts to answer all questions. Ken
#30 |
More like twins Ken! Is that red a factory color? Any fancy coolness under the hood? First thing I'll need to address is the brakes, that shouldn't be too big of a deal. The choke is very sticky, hard to push back in, and it acts as though the accelerator pump isn't working. After having it running for a while it appears an accumulation of oil gathered above the RHS head and started to smoke. Leaking from the intake manifold? Maybe?
#31 |
Looks like a solid truck. If you don't already have one, a 49-52 Shop Manual is a good investment. They are available on Amazon/eBay for about $30, typically.
#32 |
Yes, got one of the paper versions on the way.
#33 | |
1937 Ford 1 1/2 ton Deluxe Panel (78-80D) 1937 Ford Deluxe 4dr Touring Sdn (78-73D) 1928 Ford Model A Tudor Sdn (55-A) 1928 Ford Model A TBD MTFCI & AACA Tacoma Model T Club Tyee Old Car Club Gallopin Gertie Model A Club |
#34 |
Hey Art that is one nice looking truck
, post some more pictures when you get it home. After you fix the safety issues, I would just drive it to see how the motor shakes out.
#35 |
#36 | |
The engine didn't make any nasty sounds. I wonder if the oil leak could be back at the fuel pump? If the V8 is anything like the Model A, it can be pretty tired and still run pretty good. The accelerator pump probably has a check valve? Maybe it's just gunked up.
#37 | |
I thought you could be President and I'll be Newsletter Editor, Librarian, Historian, Facebook Group Administrator..we wouldn't need a Treasurer instead dues into the club are 12 self address stamped envelopesto get the newsletter!...And how about this for a newsletter name?.."The V8 Courant"... nice find, welcome to the v8 brotherhood benny
#38 |
Nothing like moving an old pickup with no brakes, in the pouring down rain...
#39 |
#40 |
Spent some time getting the truck running a little better. Pretty pleased with the progress so far. The gas is old, which isn't helping but at least it is starting well. The choke cable was all bent up and sticky, straighten and lubed it up and is working pretty good now. The throttle return spring was anchored to the rubber hose running to vacuum line on the distributor! Where is the throttle return spring supposed to go? Anyway, I put together a bit of a walk-a-round video. I should have a new master cylinder tomorrow... might get a drive around the block!
![]() https://www.youtube.com/watch?v=X4v7...ature=youtu.be |
| Thread Tools | |
| Display Modes | |
