Old 11-26-2012, 03:37 PM   #1
Dutchtreat
Dutchtreat's Avatar
Talking 1946-1948 Ford truck Centersection what's it worth
I am cleaning out the Garage and have a 1946-1948 Truck(open) centersection. I also have a set of Car 42-48 bells and a complete diff with axles to go with it.
1st. Cav Trooper
Operation Garry Owen
F Troop 9th Cav'71-'72
Dutchtreat is offline   Reply With Quote
Old 11-26-2012, 04:50 PM   #2
bgarrett
bgarrett's Avatar
Default Re: 1946-1948 Ford truck Centersection what's it worth
$319.47
bgarrett is offline   Reply With Quote
Old 11-26-2012, 04:54 PM   #3
Dutchtreat
Dutchtreat's Avatar
So How did you arrive at that number??ha ha
1st. Cav Trooper
Old 11-26-2012, 08:28 PM   #4
Tim Ayers
That x-member goes from between $50-$100. Depends on condition and how it was removed. If torched and with rust pits, low side of price range. If no rust pits and rivits were removed, then higher side of range.
Old 11-26-2012, 08:50 PM   #5
PeteVS
PeteVS's Avatar
Tim: I think he's talking about the banjo casting with the parts for a yoke for an open driveshaft, not a center crossmember. (Are you thinking F1 center crossmember?)
Dutch: The axle bell values will probably hang on the condition of the rear hub bearing surfaces. If those surfaces are worn, that's a lot of $ to get them back to usable.
Old 11-26-2012, 09:21 PM   #6
Tim Ayers
Yep, you're right Pete. Thanks for point that out.
Old 11-27-2012, 08:06 AM   #7
4tl8ford
4tl8ford's Avatar
The 48 and newer Ford Trucks were completely different that 47 and older, Chassis, Engine, Drive Train, Sheet metal.
Dick C
Erie, PA
1996 Exploder
1952 Ford F2 (Driver)
1948 Ford F1 Panel (Frame off resto-rod)
1946 Ford Coupe (Basket case)
4tl8ford is offline   Reply With Quote
Old 11-27-2012, 09:05 AM   #8
Dutchtreat
Dutchtreat's Avatar
Ok Guys this is the Open Drive Truck banjo that everyone wants to replace there torque-tube with. The bells are rough but rebuild-able. So I'll shoot for $150.00OBO Thanks guys.
1st. Cav Trooper
Old 11-27-2012, 10:42 AM   #9
Tim Ayers
Dutchtreat:
I sent you a PM. Depending on condition and ratio, I'm intersted. Thanks.
Tim
