#41 |
I don't recall if I said earlier that I had to shorten the drag link about 3/4 inch because the Magnum axle is 3/4 in. narrower than stock
#42 |
Yes you did. I only dropped 1 1/8 beyond stock so my drag link is good as is. Even the tie rod was good as was. I will double check that though when I drive the car and put on the lift. Car sets pretty good. About 25 1/2 from ground to fender lip. I would sure like to put on some white walls but having a hard time justifying nearly $1100.00.
#43 | |
#44 |
Your 40 sits right and looks good. With enough fender clearance you are "good to go".
Nice to see your door handles are straight. |
#45 | |
#46 |
#47 | |
I think it looked better with black walls... |
#48 |
looks great
#49 |
#50 |
Great look
