Old 03-12-2026, 09:18 AM   #1
Tom F OHIO
Tom F OHIO's Avatar
Default Hood Spring
Is there a trick to attaching this spring on my 52 2dr sedan on the hood. I can't strech it that far.
Tom F OHIO is online now   Reply With Quote
Old 03-12-2026, 11:12 AM   #2
The Art Doctor
The Art Doctor's Avatar
Default Re: Hood Spring
Yes. Bend the spring in your hand and insert quarters or washers between the coils, bend it the other way and insert more, bend it again and insert more. Eventually it will be long enough. When you shut the hood all the washers will fall out on the ground.
The Art Doctor is offline   Reply With Quote
Old 03-12-2026, 12:03 PM   #3
petehoovie
petehoovie's Avatar
Originally Posted by Tom F OHIO View Post
Attachment 582712
Old 03-12-2026, 01:00 PM   #4
Tom F OHIO
Tom F OHIO's Avatar
[QUOTE=The Art Doctor;2442001]Yes. Bend the spring in your hand and insert quarters or washers between the coils, bend it the other way and insert more, bend it again and insert more. Eventually it will be long enough. When you shut the hood all the washers will fall out on the ground.
Thanks for the response, as I will give that a try. Also, thanks Pete for blowing up the picture.
Old 03-12-2026, 02:48 PM   #5
Tom F OHIO
Tom F OHIO's Avatar
The Art Doctor definitely steered me right. My spring looks like a bug, but with the washers and just a little nudge with a screwdriver it went on. Now all I have to do is paint it up. IMG_20260312_144754540_HDR.jpg
Old 03-12-2026, 03:28 PM   #6
19Fordy
19Fordy's Avatar
That washer idea is the cat's meow. Excellent.
Old 03-12-2026, 06:12 PM   #7
petehoovie
petehoovie's Avatar
The Art Doctor definitely steered me right. My spring looks like a bug, but with the washers and just a little nudge with a screwdriver it went on. Now all I have to do is paint it up. Attachment 582715
