Old 02-06-2026, 11:54 AM   #21
TJ
TJ's Avatar
Default Re: 40 Ford drop axle
As I recall I think I used 195X75 on my '40 coupe. I have 205-75 on my current tudor '40. They are a tad too big in my opinion.
Old 02-06-2026, 01:26 PM   #22
Newc
Newc's Avatar
You all Know about using '36 axle and wishbones in a 37-40 chassis? More room for the drop and the spindle arms. Wishbone 'spread' is narrower and the axle bosses are 2".Newc
Old 02-06-2026, 01:32 PM   #23
19Fordy
19Fordy's Avatar
Originally Posted by pistonbroke View Post
I bought the bolt on arms for my 41 pickup. They were an easy way to go and avialible in one to four inch drops. Tim
As a side note: I used a Magnum 4 in. dropped axle and steering arms. Make sure the bolts that secure the dropped steering arms DO NOT BOTTOM OUT when installed. You can see the two steering arm bolt heads in photo #3. Use Loctite.
The little red cap covers grease fitting on extender to clear steering arm.
Old 02-06-2026, 02:02 PM   #24
TJ
TJ's Avatar
I've also used a Magnum axle on three cars. Instead I used Chassis Engineering steering arms as they are bolted through the arm, spindle, and the backing plates(if using drum brakes) and secured with a nut.
Old 02-06-2026, 02:42 PM   #25
petehoovie
petehoovie's Avatar
Old 02-06-2026, 10:11 PM   #26
19Fordy
19Fordy's Avatar
THANKS, Pete
Old 02-12-2026, 10:47 PM   #27
Sid
Sid's Avatar
I think I am in for a fight. I started to prepare to remove axle on 40 today. Going okay until I got ot the bolt on left perch. My impact socket my good long Snapon breaker and 2 foot cheater and still no go. Heat will be on tomorrow. I have a feeling I will need to remove wishbone from the car and leave attached to axle and work on in the open with a rosebud. My question is is the wishbone easy to unbolt from the car. I can't remember if I've ever removed one before.
Sid is offline   Reply With Quote
Old 02-13-2026, 08:26 AM   #28
sidevalve8ba
sidevalve8ba's Avatar
Heat is your friend.
Cars are like potato chips, its hard to have just one.
sidevalve8ba is offline   Reply With Quote
Old 02-13-2026, 10:34 AM   #29
19Fordy
19Fordy's Avatar
Sid, Wishbone with axle and spring assembly is easy to remove on a 40 Ford. Jack car up and remove U-bolt nuts and then wishbone cup. Do not lay down under axle assembly when doing this. USE 4 LEGGED JACK STANDS. When you use heat do not hammer directly on the threaded end of the perch bolt to harshly or you will damage the threads. Be sure to keep a threaded nut on the threads to prevent distortion. Use anti seize when reassembling.
Old 02-13-2026, 11:45 AM   #30
petehoovie
petehoovie's Avatar
Old 02-13-2026, 02:29 PM   #31
tubman
tubman's Avatar
Removing the spring perch bolts is the real problem here. It has been approached on the H.A.M.B. several times. Check this out : https://www.jalopyjournal.com/forum/...4/#post-948132.
Some folks think it is better to pull them out : https://www.jalopyjournal.com/forum/.../#post-1548429.
There are a lot of threads over there on the subject. It might be worthwhile to spend some time going through them.
Old 02-13-2026, 06:37 PM   #32
19Fordy
19Fordy's Avatar
Sid, One more thought. If your 40 doesn't have a "sway bar", now is the time to replace the perch bolts that will accommodate a sway bar.
Old 02-13-2026, 08:25 PM   #33
Sid
Sid's Avatar
Thanks 19Forty... It does have a sway bar. I got the perches out. Not too bad. I heated the boss up and took my air chisel with a blunt punch and walked them out. No damage. I notice the piece on the wishbone ball is really hard like plastic. Isn't that supposed to be rubber?
Old 02-14-2026, 07:36 AM   #34
glennpm
glennpm's Avatar
Originally Posted by Sid View Post
T I notice the piece on the wishbone ball is really hard like plastic. Isn't that supposed to be rubber?
Yes they are made of rubber. Tricks for putting on a new one:
- Lube the stall wishbone ball with silicone grease, window cleaner or dishwashing fluid
- Push on the new ball while applying air pressure to the small hole in the back which expand the ball and goes on easily.
- Heating the rubber ball up in water helps and may forgo the need for your air compressor
I've also put them on by turning them inside in a vise, use lube, push on it while turning it right side out. I use window cleaner and my sir compressor nozzle to take off and install motorcycle had grips too.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
glennpm is online now   Reply With Quote
Old 02-14-2026, 11:34 AM   #35
19Fordy
19Fordy's Avatar
One more thought:
Double nut the perch bolt. That way you can use it for jacking up one wheel ( instead of the frame or axle) without damaging the threads.
Old 02-14-2026, 02:26 PM   #36
petehoovie
petehoovie's Avatar
One more thought:
Old 02-14-2026, 09:36 PM   #37
19Fordy
19Fordy's Avatar
Thanks Pete.
Old 03-16-2026, 10:07 PM   #38
Sid
Sid's Avatar
Does the drag link and tie rod generally end up below the wishbone after a axle drop. Only did equivalent to probably a 3.25 drop. 1 1/8 beyond stock.
Old 03-17-2026, 10:12 AM   #39
19Fordy
19Fordy's Avatar
Sid, With a 4 in. dropped axle and steering arms my tie rod and drag link ended up below the stock 40 wishbone as shown in photo in post #36.
Old 03-19-2026, 02:30 PM   #40
Sid
Sid's Avatar
Thanks 19Fordy.. Got it all together yesterday. Had to pull the drag link and put it under the wishbone.
