Old 05-15-2024, 12:17 PM   #21
Model51
Model51's Avatar
Default Re: '41 PU Rear Window
Is someone willing to show a few pictures of the metal that would need to be cut or trimmed? I'm only familiar with the 1935-39 rear window opening and it would be interesting to see the difference.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 05-15-2024, 08:13 PM   #22
rawlir
Sorry, I can't, I have already installed my non sliding window & moved on....as i recall when the opening was ready there was a vertical brace on both sides of the window that would have needed to be cut out so the sliders could then move out of the opening. I don't remember if it was just those 2 pieces or not, as i said if i would have cut those out, then continued with Bob Drake installation instructions & found something else as a problem I might have faced reinstalling those 2 pieces, was not willing to got here, I am trying to install as many Period Correct options of 1947, was disappointed to not get this one done.....
rawlir is online now   Reply With Quote
Old 05-15-2024, 08:29 PM   #23
Model51
Model51's Avatar
No problem. I was just curious. On my sliding rear window the glass pains both slide inward, not outward. All that was needed was a clear opening, the same size and shape as the one-piece unit.
Old 05-15-2024, 10:08 PM   #24
alanwoodieman
drill out a couple of spot welds--will look to see if I have the ones that came out of another cab we put window in
Old 05-12-2025, 09:00 AM   #25
Ron_r1959
Ron_r1959's Avatar
I bought one for my 41, my question is what does the outside of the window look like, the kit from Drake comes with a nice trim strip for the inside but i don't see anything for the outside. Did they have trouble with air or rain leaking in? I assumed it would use the rubber molding but that isn't the case. Does the window lay against the cab window seam? what keeps rain from getting in? I would love to see a closeup picture of a Drake window installed if anyone has one? Thanks Ron
Ron_r1959 is offline   Reply With Quote
Old 05-12-2025, 07:33 PM   #26
Model51
Model51's Avatar
The rear window glass should have setting tape applied to the edge. The tape should be wide enough to go up the glass about 1/4" on each side. The tape provides the rain seal on the cab sheet metal. Ford used this technique on windshields before the advent of rubber gaskets. Attached is an image of a windshield cross section just to show how the tape wraps around the glass. The same principle applies to the rear window glass.
Old 08-01-2025, 01:32 AM   #27
Ken Patty
The cross section doesn't look like what I got from Drake to work with. But in any case the outside of the window is going to look unfinished. I don't see any way the Bob Drake kit doesn't allow for leaking inside the cab. Pretty disappointing. Am I missing something?
Ken Patty is offline   Reply With Quote
Old 08-01-2025, 10:33 AM   #28
petehoovie
petehoovie's Avatar
