#41 |
OK guys,
Thanks to all who have followed along with this journey and posed some very valid questions and suggestions. Here is the conclusion to this all. I removed the stats and took the Merc for an extended drive on Sunday. The temp was slow to rise (outside temp was 60 degrees) and NEVER got completely to N normal, this was cooler than the past two years of driving this car (Skips pumps work) so when getting back home I let the car idle till the original equipment temp gauge did get to N. I then used my just purchase laser temp gun and shot the upper rad tank and …….. the temp was 155 degrees, this is what N represents on my car! Previously when I drove with the stats and the temp needle went to the ¾ line on the gauge I saw it as running hot. At this point I will reinstall the stats, consider the ¾ line on the temp gauge as NORMAL, and call it good.
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
#42 |
Sounds good to me!
#43 |
I was waiting for ya! "Solving a problem that didn't exist" Your input MOST appreciated.
Shoebox
#44 |
When I parked my 34 after its first drive it felt hot so I used the wife's meat thermometer in the top of the radiator and got a reading of 200. So, I got new water pumps and had the radiator cleaned and rodded and the engine ran a lot cooler (170 approximately with a laser thermometer). Since then it has never ran as smoothly or as quietly as it did at the 200 temperature.
#45 | |
#46 |
#47 |
You can always drill some holes in the block if it runs too hot!
![]() Just ask Go Cat Speedshop ![]() --
tony-starr.com |
#48 |
I'd be getting a pipe thread tap and a load of plugs.
#49 |
That's the air cooled version of the flathead.
#50 |
I gotta ask the obvious question . . . who the Hell did that and for what purpose? Were they running Alky at the drags and thought they'd lose some weight? Do explain! LOL
#51 |
When we ran a B/A we never ran a radiator. We would fill it with water, seal it up, make a run and then dump the water and refill. I know a lot of engines had the blocks filled solid. I have never seen a block drilled for cooling, but that would be my guess at to what was being attempted.
#52 | |
Here's part of the description that went with that photo from @gocatspeedshop's post on Instagram. Link also below.
tony-starr.com |
#53 |
Yep, we did some wild things in the 60s. Rear only brakes, no starters, no radiators, etc.
#54 |
Have you retorqued the head bolts? If not I suggest you do it also be sure to back the head bolt off record what it took to break it loose then set it to spec. Worth a shot
#55 |
Re-torque the heads
#56 |
Me too.
