Old 02-25-2013, 11:55 PM   #1
Russ B
Default 6 to 12 V horn conversion
How to Restore Your Model A, Volume 8, pp.110-112, has a reprint of an article by Bob Hess on "Converting to 12 Volts." Part of the discussion is about modifications needed so one can reliably use their existing 6 volt horn. I would recommend that anyone planning a 6 to 12 volt conversion should look at this article.
As the reprint is from a 1991 original article, revised 2002, I found one additional update that is still needed.
Because of the heavy current draw of a horn, the author indicates a small resistor, sometimes used for dropping the voltage, does not work when converting a 6V horn for use with higher voltage. He recommended an Ohmite Divideohm part 210-100-1 RO. That part number no longer is current. Since it took a bit of searching to find the current part number and a source where I could buy it, I am posting the updated number for anyone who can use it.
The new Ohmite part number is D100K1ROE.
I found it at www.galco.com
the other side shows how it is adjusted, moving the slider bar in the middle:
The author also recommended adding a relay to the horn circuit as a means of getting a stronger current to the horn. I built a small test circuit, shown below, to be able to test and adjust the sound of my horn.
My horn still needs some adjusting as I put it together from several different, older (mostly aftermarket) horns and replacement parts. The little 2X3 board is just a simple mounting arrangement of the components of the circuit. Once I get it all adjusted, I will permanently mount the relay and resistor on the floor pan under the seat.
Russ B is offline   Reply With Quote
Old 02-26-2013, 03:09 AM   #2
BillLee/Chandler, TX
BillLee/Chandler, TX's Avatar
Default Re: 6 to 12 V horn conversion
Given that the horn is seldom used and even then in VERY short bursts, the in-line resistor that the vendors sell works just fine. While your solution is just fine, it is gross over-kill IMHO.
Bill Lee
http://www.CedarCreekAs.org
BillLee/Chandler, TX is offline   Reply With Quote
Old 02-26-2013, 04:07 AM   #3
dave in australia
I haven't tried it yet, but I have always wanted to try two horns connected in series on a 12V system. It would have one horn under each headlight. I feel it would be a good noise.
dave in australia is offline   Reply With Quote
Old 02-26-2013, 10:13 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Interesting........stereo ahooga's would certainly sound better than the jerks always driving by the house with there 500 watt stereos shaking the windows.
Old 02-26-2013, 10:38 AM   #5
MikeK
MikeK's Avatar
There are black boxes to clone/hijack blue-tooth links. With a 5 Watt transmitter and a digitized horn mp3 file you could override and make their bluetooth enabled 500 watts go AHOOGA! as they drive by. LINK1. . .LINK 2
MikeK is offline   Reply With Quote
Old 02-26-2013, 06:53 AM   #6
2manycars
2manycars's Avatar
Since converting to 12 volts removes the car from the realm of original, why not use a new 12 volt horn from A&L and sell the original to someone who is restoring an original car?
2manycars is offline   Reply With Quote
Old 02-26-2013, 11:04 AM   #7
JoeWay
JoeWay's Avatar
This has got to be in the running for the "Top Ten Silliest Comments by a PURIST" awards.
Here's a link to a pdf version of a post I made to the old FordBarn about converting a horn to 12v.
I got my wire from McMaster-Carr. Radio Shack no longer carries a suitable wire for this project.
http://originalmodelaparts.com/Misc/WayHornRewind.pdf
Joe
1929 Tudor
since 1962
Feather River A's
JoeWay is offline   Reply With Quote
Old 02-26-2013, 11:59 AM   #8
2manycars
2manycars's Avatar
Joe
I did not think it was silly, I thought it was a good alternative. I have had friends who did just that. I dont consider myself a purist, either.
Old 02-26-2013, 07:26 AM   #9
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
One other thought, since most people that are converting from 6 volts to 12 volts find themselves purchasing a different ignition coil that is compatible with the 12 volt system, that leaves them with a 6 volt coil that is no longer used. Why not use the 6 volt coil as the resister??
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-26-2013, 07:27 AM   #10
Del in NE Ohio
Del in NE Ohio's Avatar
Bratton's sells a small resistor that you place inside the horn cover.. very small works great.. I have been using one for approx 10 years. 5 min installation
Del in NE Ohio is offline   Reply With Quote
Old 02-26-2013, 10:23 AM   #11
CarlG
CarlG's Avatar
That's the one I'm using. No problems here either.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-26-2013, 07:42 AM   #12
MikeK
MikeK's Avatar
Adding a resistor to a 6V motor for 12V operation is not a conversion. It is a dirty fix that converts an amount of energy equal to the motor draw into heat. A true conversion would involve rewinding the field coils so no resistor is needed. The armature remains unchanged. After this is done you will need only half the amperage a 6V+resistor setup will draw. No relay will be needed. No need to put a resistor that will get smokin' hot during a parade under a flammable seat. There have been several write-ups on how to do this.
Old 02-26-2013, 10:34 AM   #13
jrelliott
jrelliott's Avatar
If you want to make a good converter, go to
www.studebaker-info.org/tech/6-12V/6-12-6.htrr . This converter works better than a dropping resistor. JMHO
jrelliott is offline   Reply With Quote
Old 02-26-2013, 11:43 AM   #14
melmallory
We have had good luck soldering a shunt wire across the two wires comming out of one of the feilds in the horn. This basically puts that feild out of service, allowing the horn's rpm level to stay the same other than double. Did mine quite some time ago still works fine.
melmallory is offline   Reply With Quote
Old 02-26-2013, 12:01 PM   #15
Purdy Swoft
Purdy Swoft's Avatar
I also use the old repro ahooga horns. most will work just as well on 12 volt and are much louder.The one on my roadster is marked 12v. I didn't like the sick cow sound of the old original horns. You could smell the smoke even on 6 volt. I also figured if I needed to use the horn as a warning, nobody would hear it. My horn is good and loud, we like it and it looks pretty close to like an original after installing a name plate. I also have an original on the shelf that works if anyone needs one, it came off a november 28 leather back fordor.
Old 02-26-2013, 05:02 PM   #16
bettlesr
bettlesr's Avatar
I rewound mine. only took a couple of hours. The starting current of the motor is higher than the running current, with the dropping resistor, the motor slowly gets up to speed. If you use a lower resistance, the motor starts fine and then runs too fast. Not really a problem unless you do a lot of parades, where the horn is run semi-continuously.
I don't remember for sure but I think I removed 50 turns of 20 gauge wire on each field and replaced them with 100 turns of 24 gauge wire. Now it runs just like it did originally on 6 volts.
1965 Lotus Elan S2
1930 Model A Sport Coupe
bettlesr is offline   Reply With Quote
Old 02-26-2013, 06:12 PM   #17
Joe K
Joe K's Avatar
I have three of these Western Auto horns hanging around. One came with the truck, one I picked up at a flea market and the last I bought because it was marked 12v.
Using them on 6V definitely they're different sounding. The 12V used on 6V gets the sick cow award. But I've also noticed that the horn underneath the covers are the same, but that the field winding is parallel on one (6V) and series on the other (12V)
So maybe it's possible to examine one's original or other horn and make a change in the field wiring and do away with resistors?
Maybe one of the horn rebuilders could comment? We're a pretty knowledgible crowd around here.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 02-26-2013, 09:43 PM   #18
Purdy Swoft
Joe K
My first horn came from J.C. Whitney in the seventies It still works good on 6v All of my repro horns adjust through the bell. I think some are Hutchins they all have one screw that holds the motor cover. One of the 12v horns has a slightly longer rear cover and is pretty loud.
Old 02-26-2013, 09:56 PM   #19
Joe K
Joe K's Avatar
When I first bought my Model A, I thought the el-cheapo was how the Spartan horns looked. WRONG. It's just a cheap knock-off.
Still, I like them. I'll get closer to a real spartan on my Truck, but the huckster yet to be built I'll allow myself some variation.
I like the fact of a car made from essentially nothing except my time and talent and interest. And all those spare parts that I have been gifted with over the years as my neighbors and friends cleaned out their barn.
And the 12V horn was headed for my modern car.
Joe K
Old 02-26-2013, 06:38 PM   #20
Tom Wesenberg
The original horn feeds the power through one field winding, then through the armature, and then through the other field winding, so it is a series winding already.
