Old 02-18-2013, 09:24 AM   #1
JonC
Default 40 P/U Hood vs. 40 Std. Car
I am looking for a hood for my 40 pickup. I guessed that Ford would not have made three different hoods in 40 for the cars and light truck 1/2 ton. I recently asked a well respected member his opinion and he agreed that two hoods were offered, the deluxe and std./P/U or at least that is what I took him to say.
I placed an ad and had someone contact me and tell me I was ill informed and the hood for the P/U is a special. I can't believe that, but how can I verify it. Is it documented anywhere like the 40 book. I am inclined to believe tooling for hoods were expensive, so why would Ford build new tooling for a hood when the vehicles are so close looking from the front. Jon
JonC is offline   Reply With Quote
Old 02-18-2013, 09:34 AM   #2
oldrelics
Default Re: 40 P/U Hood vs. 40 Std. Car
The pickup hood is way different. Car hoods will not work.
oldrelics is offline   Reply With Quote
Old 02-18-2013, 09:52 AM   #3
Mart
Mart's Avatar
Pickups are taller, the hood is deeper to compensate.
Mart.
Old 02-18-2013, 10:46 AM   #4
RPM
Cars have stainless trim strips down the sides, pickups do not. Trucks have a raised bead or feature bead instead. Take a good look at any pictures on the net, you will see what I am explaining. Furthermore, trucks are about a half inch taller in the nose (and cowl area) explaining why the nose ornament is truck only, not car. The 40 STD (car) hood stamping is basically a carryover from 1939 DLX car production. Therefore, Ford stamped only two new hoods in 40, one for cars (the Deluxe) and one for half tons. For your truck you need a 40 or 41 half ton hood. The 41 has more and larger trim holes (for the wider deco trim) but can be retro-ed to 40 trim. Nothing else will bolt up with out cutting and welding (unless you are building a custom such as car nose on truck). Hope this helps. RPM
RPM is offline   Reply With Quote
Old 02-18-2013, 12:25 PM   #5
JonC
Thanks for the replies, now to find a 40/41 P/U Hood
Old 02-18-2013, 01:16 PM   #6
Roger/Sacramento
Roger/Sacramento's Avatar
I have a '41 that I trimmed out as a '40....not a big project but some filling of trim mounting holes necessary. The hood locking item is different depending on what the pickup had for a motor ( 4,6 or V8). Mine was originally a 6 and caused me some confusion because of how different the lock mounting brackets were compared to a V8 that I looked at. I took it all out and went with a cable lock. It was a lot of work but, I like it better.
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS.....
http://s818.photobucket.com/home/roglehr/index
Roger/Sacramento is offline   Reply With Quote
Old 02-18-2013, 06:23 PM   #7
JonC
Beautiful truck, I can only hope mine gets together let alone look as good as yours. now for the Gasp part, you mean not only do I need to be concerned with the year and P/U hood I have to know what motor was in it?????? Ughhhhh.
Old 02-18-2013, 07:41 PM   #8
landshark
Look for a 40 pickup hood will make the whole front end fitting experience easier watch out for 6 clyinder hoods
landshark is offline   Reply With Quote
Old 02-18-2013, 07:44 PM   #9
landshark
Where in central ny i am around saratoga
Old 02-18-2013, 10:30 PM   #10
JonC
Gilbertsville is 20 miles southwest of Oneonta about an hour and a half from you.
Old 02-19-2013, 09:59 AM   #11
stovebolt
stovebolt's Avatar
The most obvious difference is where the sides of the hood meets the cowl. The passenger car cowl and the pickup cowl is totally different.
stovebolt is offline   Reply With Quote
Old 02-19-2013, 10:27 AM   #12
Charlie ny
Jon,
Alice and I attend the Canfield Ohio swap meet 2x a year. For the last two
years a fellow who sets up near us has brought a nice '41 truck hood. I don't
know his name but he sold me the nose piece off the hood.
Spring Canfield is May 3 4 & 5 let me know and I'll look for him and hook you
guys up if you are interested. It's worth a shot. The nose trim holes in a '41 hood
are pretty big but for sure it can be retroed to a '40.
Charlie ny
[email protected]
Charlie ny is offline   Reply With Quote
Old 02-19-2013, 11:55 AM   #13
JonC
Charlie, I sent you an E-mail Thanks
Old 02-19-2013, 11:57 AM   #14
JonC
Speaking of hoods, does anyone know if the under hood bracing is being reproduced, a couple of folks have contacted me with hoods but no bracing....
Old 02-19-2013, 07:27 PM   #15
landshark
as far as i know not being reproduced. i just bought a t brace for a 40. i put a ad in the wanted section and got a couple hits. have had good luck finding parts on this site
Old 02-20-2013, 09:57 AM   #16
JonC
Thanks I have put in an add.
