Old 02-05-2013, 12:27 AM   #1
hotrodalley
hotrodalley's Avatar
Default 31 cabriolet windshield
I am looking for some direction on 68B windshield.
1. Is there a rubber seal above hinge similar to coupe?
2. Is rubber gasket same as coupe?
3. What are the correct screws to mount windshield hinge to header?
Thanks
hotrodalley is offline   Reply With Quote
Old 02-05-2013, 12:43 AM   #2
spike
Default Re: 31 cabriolet windshield
yes same as coupe....round head wood screws un finished or blue steele dont know my sizes in wood screws sorry.
spike is offline   Reply With Quote
Old 02-05-2013, 08:37 AM   #3
jw hash
jw hash's Avatar
yes the seal is the same as the coupe with exception the outer two hinge screws are in a different lacation. so you have to punch a couple holes and if you are using a standard hinge you will have to drill a couple hole. the screws 1/4-20 X5/8" slotted stove bolts
jw hash is offline   Reply With Quote
Old 02-05-2013, 11:07 AM   #4
eystein
eystein's Avatar
Is this the correct rubber seal above the hinge ?
eystein is offline   Reply With Quote
Old 02-06-2013, 01:20 AM   #5
jw hash
jw hash's Avatar
there is a couple of versions of that rubber does that one fit your hinge good. the one for the slant window is a different size and not by much.
