Old 07-30-2010, 08:19 PM   #1
Thom IV
Thom IV's Avatar
Default Sick Engine
Need some advice and things to check for.
My 31 Rdstr isn't running well. Lack of throttle response, backfiring through the carb. Necessary to have GAV open almost a full turn in order to get engine to run smooth. Last time I drove it best speed was 35 MPG with throttle to the floor. Starts good. What should I be checking?
Thanks in Advance for your thoughts
Thom IV is offline   Reply With Quote
Old 07-30-2010, 08:30 PM   #2
MCHinson
MCHinson's Avatar
Default Re: Sick Engine
I woiuld check for:
Fuel restriction (crud in line or carb somewhere), Bad Coil, Bad Condenser, or timing problem. One of these would probably be my first guesses.
MCHinson is offline   Reply With Quote
Old 07-30-2010, 08:52 PM   #3
MikeK
MikeK's Avatar
If it turns out to not be a fuel delivery or ignition/timing problem, check for a possible bad intake manifold to block gasket or a head gasket leak between 1&2 or 3&4. Do you have a vacuum gauge and a compression tester?
MikeK is offline   Reply With Quote
Old 07-30-2010, 08:52 PM   #4
TK in LA
TK in LA's Avatar
For sure, check the fuel supply. Disconnect the line going into the carb, Either put an appropriate size hose on it or hold it over a can and have someone turn on the gas valve on and check the flow. It should be a very solid stream. Also check that the gasket in the gas cap hasn't plugged the vent. Let us know what you find!
TK in LA is offline   Reply With Quote
Old 07-30-2010, 09:28 PM   #5
Rainmaker Ron
Rainmaker Ron's Avatar
You have a massive vacuum leak, probably at the intake to block gasket. This will require truing the manifolds and intalling a new gasket. The symptoms are classic, starts good and idles fine. Will not rev up or make power. GAV must be opened to compensate for unwanted air. Could also be caused by a warped flange on the tillotson carb or a cracked intake manifold. An intake valve stuck open will cause similar problems but usually be hard starting also.
Rainmaker Ron
Rainmaker Ron is offline   Reply With Quote
Old 07-30-2010, 09:38 PM   #6
'29wagon
sounds like timing is too advanced, way too . start with the timing ?
'29wagon is offline   Reply With Quote
Old 07-30-2010, 11:30 PM   #7
mass A man
mass A man's Avatar
Thom, Try turning the small mixture screw on carb when engine is idling, if you don't see or hear any difference, Rainmaker Ron hit it right on the head--- Air leak!
mass A man is offline   Reply With Quote
Old 07-30-2010, 11:37 PM   #8
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Rainmaker Ron
Ron,
In this case would someone try to use a propane torch (not lit) and wave it around the area where the leak is suspected to see it engine increases speed?
Old 07-31-2010, 08:01 AM   #9
1931 flamingo
1931 flamingo's Avatar
I would think a spray can of WD40 would be A LOT SAFER! JMO
Paul in CT
Old 07-31-2010, 09:51 AM   #10
Purdy Swoft
Purdy Swoft's Avatar
Paul in CT
Paul, I agree, WD40 use to work good for such tests and was really some wonderful stuff. They changed the formula and WD 40 is no longer flamable. Now that WD is no longer flamable it will no longer let the engine speed up when sprayed over a vacume leak. When I last tried is on my 29 strip down it ran down the side of the valve cover and left dark ugly streaks from around the manifold on my purdy fresh painted engine.
Though it is very flamable I think that starting fluid works best, it evaporates quick and won't stain the engine. If there is a vacume leak it will tell the story right now.
Old 07-31-2010, 11:17 AM   #11
Rainmaker Ron
Originally Posted by Mike V. Florida View Post
Ron,
Mike, I used that idea for years but lately found it had no effect. I see from Purdy Swoft post that WD 40 is now non flamable..no wonder it stopped working as a test!
Rainmaker
Old 07-31-2010, 12:18 PM   #12
johnbuckley
johnbuckley's Avatar
Possibly h/gasket , but more likely weak mixture. as well as above suggestions I've been caught out by having no vent on gas tank cap. Whoopsy.. swapped gas cap (which is vented) and rad cap (which isn't vented)! Doh!
johnbuckley is offline   Reply With Quote
Old 07-31-2010, 04:45 PM   #13
marc hildebrant
marc hildebrant's Avatar
Could also be float at wrong level causing lean mixture.
Marc
marc hildebrant is offline   Reply With Quote
Old 07-31-2010, 04:58 PM   #14
John Stone
John Stone's Avatar
It may be something simple as the main jet stopped up. Especially if the car has not been driven for a while. Gas will evaporate through the jet and leave a residue. The new gas is nasty stuff.
John Stone is offline   Reply With Quote
Old 08-01-2010, 06:35 AM   #15
allen
allen's Avatar
Send a message via ICQ to allen
Here is a easy way to test for vac leaks hold you finger over the carb, do not completely cover it slowly close you fingers covering the opening if a vacuum leak is there the motor will rev up, if not will choke down
allen is offline   Reply With Quote
Old 08-01-2010, 10:10 PM   #16
jimnungesser
jimnungesser's Avatar
Send a message via AIM to jimnungesser
I agree with john stone above.
Jim 160b sw fordoor
jimnungesser is offline   Reply With Quote
