Old 12-27-2012, 10:25 AM   #1
Bruce,Upstate NY
Default Recent Distributor cams
I have new distributor cams from two well known dealers. They look rough to me on the point opening ramp. Seems to me that they will be hard on the rubbing blocks. Anyone agree with me?
Bruce,Upstate NY is offline   Reply With Quote
Old 12-27-2012, 10:40 AM   #2
CarlG
CarlG's Avatar
Default Re: Recent Distributor cams
Use Bill Stipe's distributor cams, you can't beat them for quality and / or price!
Old 12-27-2012, 10:47 AM   #3
P.S.
Hi Bruce,
Yep, noticed the same thing. Took a Dremel tool to the last one I got- Smoothed and then polished the cam to mirror shine, then installed. After 500 miles, absolutely NO wear on the points block at all! Points gap still at exactly .021 on all 4 lobes.
P.S. is offline   Reply With Quote
Old 12-27-2012, 10:47 AM   #4
Charles Reese
Charles Reese's Avatar
contact info for this gentleman, please
Charles Reese is offline   Reply With Quote
Old 12-27-2012, 10:52 AM   #5
wrndln
The question I have with distributor cams is: do the original cams wear any appreciable amount? It would seem to me that with the relative soft fixed contact block, there would be very little wear unless the fixed block was worn down to metal. I have several of what I believe are original cams. Is there a way to measure them to see if they are good?
Rusty Nelson
Old 12-27-2012, 10:55 AM   #6
CarlG
CarlG's Avatar
http://www.stipemachine.com/index_files/page0017.htm
Old 12-27-2012, 11:45 AM   #7
harleyjj
harleyjj's Avatar
I agree with CarlG!
I used a cam from Snyders that ate the rubbing block off a set of points before I could get out of my driveway!
Ordered a cam from Stipe Machine and have no issues at all.
harleyjj is offline   Reply With Quote
Old 12-27-2012, 11:52 AM   #8
John LaVoy
John LaVoy's Avatar
In the Spring issue of the Model A Times we have an article where we did some testing on the Stipe cam. Not only well made but improved performance.
John LaVoy is offline   Reply With Quote
Old 12-27-2012, 12:22 PM   #9
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Rusty Nelson
I don't think so but the new cams are ground differently and will give better performance.
Old 12-27-2012, 12:29 PM   #10
2manycars
2manycars's Avatar
A&L makes quality distributor cams in the model B profile, which is better than the A profile.
2manycars is offline   Reply With Quote
Old 12-27-2012, 02:34 PM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
Look at the cam under a magnifying glass. It may be made from powdered metal and what you see as roughness may just be the normal look of powdered metal parts. Those holes are good for holding cam lube.
The picture shows how easy it is to tell the difference between the "A" and "B" cams. The "A" cam has 8 lines, while the "B" cam has 4.
Old 12-27-2012, 02:56 PM   #12
RonC
RonC's Avatar
Here's a NOS genuine Ford Model B cam. Notice the polished finish on the lobe
RonC is offline   Reply With Quote
Old 12-27-2012, 05:22 PM   #13
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I've seen so called "REBUILT" store-bought distributors with the cam lobe BEAD BLASTED!!! Don't ever call me "STUPID"!!!!!!!!! bILL w.
"THE ASSISTANT GURU OF STUFF"
Old 12-28-2012, 11:38 AM   #14
Jim Brierley
Original cams do wear. I ran a B dist. years ago and there was as much as 4 degrees difference from the 90* spacing that should have been there. Stipe's cam will give you more coil duration time too, for a hotter spark.
Jim Brierley is offline   Reply With Quote
Old 12-28-2012, 11:55 AM   #15
Big John
use a micrometer or a dial indicator on the lobes of a repro cam or even an original cam to get the most accurate reading of the lobes... then use the closest one or adjust the lobes to true it up.....
Big John is offline   Reply With Quote
