Old 07-29-2010, 07:54 PM   #1
hardtimes
hardtimes's Avatar
Default brake noise..
Fairly new(1000mi) brake job..entirely new on my 30 roadster. Used original brass wire impregnated woven lining..same as original(?)!
When starting out on a run, for the first three/four times putting the mechanical brakes on...terrible squeeling noise. Thereafter, when heated up, quiet as a mouse ..no matter how hard/soft applied! Any guess why noisey when 'cold'??
hardtimes is offline   Reply With Quote
Old 07-29-2010, 09:42 PM   #2
Jim Boehmke
Default Re: brake noise..
I used the extra thick woven linings from Brattons also on my "31 coupe. My brakes also squeel when cold but not sure why. Good news is it stops on a dime and gives a nickel change.
Jim Boehmke is offline   Reply With Quote
Old 07-29-2010, 11:42 PM   #3
mass A man
mass A man's Avatar
Just finished up a brake job using the same linings from bratton's and there is no squeal, hot or cold. Now I'm wondering it could be something going on with your drums to make the noise? I'm running original drums, in pretty good shape and yes, this "A" will stop on a dime also!
mass A man is offline   Reply With Quote
Old 07-30-2010, 07:40 PM   #4
hardtimes
hardtimes's Avatar
Thanks. You may have something there, regarding the drum types! I have new type on front and originals on rear. REAR is where squeeling is occurring. Hmm, guess will take off rears and see if anything unusual happening.
Old 07-30-2010, 08:22 PM   #5
Art Bjornestad
Art Bjornestad's Avatar
My friend had very noisy brakes and solved the problem by hooking a screen door spring around outside of the brake drum nearest the inside edge.
Art Bjornestad is offline   Reply With Quote
Old 07-31-2010, 12:00 AM   #6
hardtimes
hardtimes's Avatar
Art,
Now you've got me wondering!
wondering why the noise on a rebuilt system, and why a screen door spring would quiet that noise?? Hmm, mabe a trip to the hardware store in future!!
Old 07-31-2010, 12:26 AM   #7
mass A man
mass A man's Avatar
Dear Hardtimes, Been trying to figure this one out since yesterday- You say sqeaking is coming from the orig. rear drums?, not the new cast fronts? The only thing I can think of is the old drums are glossed on the braking surface inside drum. I had the A out again today and I do enjoy the quietness of the new brakes. Best of luck!!!!-Pete.
Old 07-31-2010, 12:26 PM   #8
Patrick L.
Patrick L.'s Avatar
The woven linings are generally used with steel drums.. Are the linings riveted tightly and evenly to the shoes and have the ends been chamfered ?? Has any glaze been sanded from the drums or were they turned and appear a bit rough ?? Springs around brake drums used to be fairly common, it was to stop harmonics/vibrations.. I guess I never knew for sure whether it really worked or not, I guess now I know..
Old 07-31-2010, 01:56 PM   #9
Aerocraft
Aerocraft's Avatar
I have often wondered what the answer is to the question of squealing. This Spring I removed very good woven lining from the rear brakes of my 40B and replaced it with molded lining with the ides that I might stop the loud squealing. The Roadster has low mileage and has excellent uncut steel drums all around. Even the roller tracks show no wear. The noise stopped. The fronts had earlier been replaced with molded lining. The question remains: why? Gar Williams
Aerocraft is offline   Reply With Quote
Old 07-31-2010, 02:41 PM   #10
Patrick L.
Patrick L.'s Avatar
Well, I can't say much about Model A brake noise.. But, most noise from air brakes comes from improper installation of the blocks/ friction material..Removal and correct installation of the same blocks will correct the problem.. Thats not much of an issue today since virtually no one rebuilds these shoes anymore, they just buy rebuilts.. So maybe the Model A noise is from improper installation which allows the linings to wander around a bit.. Is anyone having noise problems with molded/glued linings with chamfered ends??
Old 07-31-2010, 03:45 PM   #11
MikeK
MikeK's Avatar
The squeal is caused by the frequency of the grab-slip of the shoes being the same as the harmonic frequency of the rear drums. Changing the mass or resonance characteristics of the drum will make it will stop.
Some old-time fixes: 1)Wrap a heavy screen-door spring around the drum. Overwrap it with friction tape if necessary to keep it in place. 2)Cut several 1" wide rings radially from an old inner tube. Stretch the bands over the drum. 3)Add a heat-and-shrink steel drum band. You might also try hack sawing 1/16" deep slots 1" apart, at a 45 angle across the shoe linings. If all else fails, get a 1000 watt sound system.
MikeK is offline   Reply With Quote
Old 07-31-2010, 08:53 PM   #12
skip
Banned
Well Hard Times..brake noise = vibration from hard friction material and brake dust.
Ever listen to a taxi cab. Those binders are only for hard use and long life. Really soft shoes make a lot of dust but are quiet as the friction material absorbs some of the vibes. The parts guy at NAPA will ask if you want good, better or best? He means. Hard, medium, or soft friction material. So I have been told i the Bendix Brake School back in the 1960's.
Maybe woven or non-woven shoes used on the incorrect brake drum material. Steel or cast iron? One set-up is correct. One set up is not correct. Maybe that's the cause of the vibes?? Sorry I don't know which is which.
skip.
skip is offline   Reply With Quote
Old 08-01-2010, 03:51 PM   #13
hardtimes
hardtimes's Avatar
THANKS all of you guys for your input!
Wow, now I not only know why, but also how to alleviate! BTW, my brakes were done, back to original and better standards(lining trued to drims)by a master model a guy who also happens to be a national model a judge and seems there isn't anyone that doesn't know him or of him! Hmm, 'hormonic frequency'...should have known, as I'm a harmonica player(grin)!
Old 08-01-2010, 09:29 PM   #14
jimnungesser
jimnungesser's Avatar
Send a message via AIM to jimnungesser
I FIXED MY SQUEALING BRAKES BY REPLACING ALL MY BRAKE DRUMS WITH CAST IRON DRUMS.
Jim, 31 sw fordoor
jimnungesser is offline   Reply With Quote
Old 08-01-2010, 10:12 PM   #15
hardtimes
hardtimes's Avatar
Jim, 31 sw fordoor
Jim,
Thanks for that info. Yeah, Skip/others explained regarding the squealing vs hardness of materials. I take it that this will definitely include the 'old vs new drums. I intend to get two new cast drums for rear, when funds allow. Till then Mike advice/remedies are like gold! Rick
Old 01-05-2016, 10:42 AM   #16
Chris Van
Chris Van's Avatar
I was at my wits' end with my shrieking brakes. They sounded like a banshee. So loud that when I came home at night I'd have to go round the block and uphill so as not to have to use the brakes at my gate, so bad were they.
I tried binding soundproofing material round the right front drum (the clear culprit) with wire (the self-adhesive type came apart with the heat of the brakes) then I removed the drum to hacksaw slits into the linings. I duly did the right hand shoe... and then noticed that the left hand shoe's bonded lining had all but come away from the shoe! I could even pull it away by hand. Voila...! It was instantly clear that the shrieking brakes was the loose lining.
A friend (Mike Leisegang) from down the road had a pair of second hand perfectly good shoes in stock - replaced both shoes on the right front - and now my brakes are silent and perfect (Mike set them up for me while we were about it).
Hope this helps somebody, somewhere...
Chris Van is offline   Reply With Quote
Old 01-05-2016, 11:06 AM   #17
zzlegend
zzlegend's Avatar
Whew,,,,,,,,,,,,,,,a 5 1/2 year old thread, brought back to life.
zzlegend is offline   Reply With Quote
Old 01-05-2016, 11:38 AM   #18
johnbuckley
johnbuckley's Avatar
Add to that,....4) encircling drum with Jubilee clips ( do you call them that- worm drive hose clips anyway) use two or more joined together so the drum doesn't get out of balance.
johnbuckley is offline   Reply With Quote
Old 01-05-2016, 01:52 PM   #19
700rpm
700rpm's Avatar
It took that long to get from South California to South Africa, maybe.
Ray Horton, Portland, OR
